ObjectPlant 2.1.6, object-oriented analysis and design tool
Post by Info-Mac » November 11th, 1999, 11:00 am
Download: http://archive.info-mac.org/dev/object-plant-21.hqx
The ObjectPlant is a shareware program for Object Oriented Analysis
and Design. It supports the OMT and UML notations and its main
features are:
+ Object Model Diagrams
+ Event Trace Diagrams
+ State Diagrams
+ Use Case Diagrams
+ Exporting diagrams in either PICT or EPS format
+ C++ and Java code generation
+ Only 25 USD for a single user license
+ For 10 USD extra you also get a Java and C++ parser
to reverse engineer code
Requirements:
System 7.1 or higher
68020 or better
Info, updates etc can be found at
Mikael Arctaedius
Stockholm, Sweden
