iPhone 4 flash problem
The flash on my phone is useless. I'm not sure if it's my phone or if there all like this. All the pictures come up milky and all white that you can't see anything. I do not have a case so that's not the issue. Is it the phone or is this a known issue? Thanks for the help
Re: iPhone 4 flash problem
If you don't have a case, then either you're putting your finger(s) too near to the flash or your phone is broken. When I first got my iPhone 4, I used my old iPhone 3G's Speck case before getting a new one made for the iPhone 4, and it had the same effects you describe.newsvt wrote:The flash on my phone is useless. I'm not sure if it's my phone or if there all like this. All the pictures come up milky and all white that you can't see anything. I do not have a case so that's not the issue. Is it the phone or is this a known issue? Thanks for the help
Here is a night-time picture taken with my iPhone 4's flash in a dark corner of Northerly Island, Chicago. There was no other light source.
