Download: http://archive.info-mac.org/data/troi-t ... n-2702.hqx
Troi Text Plug-in is a very powerful tool for for dealing efficiently
with text in your FileMaker Pro database. It adds the following
functions to FileMaker Pro:
- Combine sets from 2 text fields:
* get all lines that are the same
* get all lines that differ
and other combinations
- Get (unique) lines and sort words and lines
- Make a text sum from a related file that even updates without a script
- Parse XML text into fields
Suggested Uses
- Present portal information horizontally
- Create an index for a book, which is updated automatically
- Find all addresses you want to send an email to, without sending
duplicates
- Keep track of your client relations by generating a dynamic history of
activities
- Receive client information in XML format and parse it easily into your
database
All these features also work in a runtime solution.
Troi Text Plug-in 2.7.0.2 has these improvements:
- Converted to the new External Function API of FileMaker Pro 7.
- Each function can now handle longer texts than the previous limit of
64000.
- Each function now supports Unicode characters.
- (Mac) Registration now also works if the registration file has a
".txt" extension at the end.
- New and updated example databases, which illustrate the use of each of
the functions.
- Updated user guide and function overview.
Troi Text Plug-in is shareware and costs US$ 39.
System requirements
Any Mac or Windows machine that runs FileMaker Pro 7. The plug-in is
available for Mac OS X (10.2.8 or later), and for Windows 2000 (Service
Pack 6) or Windows XP.
For more information, please read the Read Me file enclosed, or visit
our
Web site at: .
