Download: http://archive.info-mac.org/cfg/cmm/spe ... cm-111.hqx
What is Speak Text CM?
Have you ever wanted your computer to read your e-mail to you? Have
you noticed that reading a paper out loud helps to find mistakes?
Speak Text CM will speak the selected text in any program. Speak Text
CM and Speak Text Engine are not INITs, but are a Contextual Menu
plugin and an application, respectively, so they should not cause any
conflicts.
PPC Macintosh
Requires 8.0 or newer.
Changes in Speak Text CM 1.1
Added Speak Text Engine to speak text asynchronously, and to allow
large voices in all applications
Changes in Speak Text CM 1.1.1
Changed URL where "Contextual Menu Enabler" and "SOMobjects for Mac
OS" can be found, in the readme.
[This should replace all earlier versions]
Paul Westbrook
[email protected]
