Delphi Mac Digest V2 #55
Path: utzoo!mnetor!seismo!rutgers!sri-spam!nike!ucbcad!ucbvax!RED.RUTGERS.EDU!SHULMAN
Newsgroups: mod.mac
Subject: Delphi Mac Digest V2 #55
Date: Thu, 30-Oct-86 09:40:46 EST
Article-I.D.: RED.12250935892.51.SHULMAN
Posted: Thu Oct 30 09:40:46 1986
Date-Received: Fri, 31-Oct-86 02:13:03 EST
Lines: 709
Delphi Mac Digest Thursday, 30 October 1986 Volume 2 : Issue 55
RE: DS copier beta - problem (Re: Msg 14178) (7 messages)
PhoneNet/LaserWriter+ problems (3 messages)
New Excel Version
Re: Re: Prob: interpreting Pascal to C -
Computers and Medical Charts (3 messages)
Packbits
News from the Meadow
RE: LightSpeed C/Loadseg hangs! (Re: Msg 935) (3 messages)
MS Word 3.0 for the Mac (5 messages)
RE: Word 3.0 -- A Mirage? (Re: Msg 14275) (2 messages)
Re: Lisa to Mac compatibility
Weird font problem
DrawMenuBar() tidbit
alarm clock menu blink
RE: TeX (Re: Msg 14274)
RE: INFO-MAC Digest V5 #2 (Re: Msg 14282) (2 messages)
Word / WriteNow
Dataframe Squeal (2 messages)
DiskTimer results
Subject: RE: DS copier beta - problem (Re: Msg 14178)
Date: 25-OCT 14:45 Programming
Try a _FlushVol on the volume before you Eject it.
Subject: RE: DS copier beta - problem (Re: Msg 14186)
Date: 25-OCT 15:37 Programming
OK, I'll try it, but I think that's going to update sector two also. Thanks
Subject: RE: DS copier beta - problem (Re: Msg 14187)
Date: 25-OCT 20:47 Programming
If the problem is the fact that there was another disk in that drive prior to
the copy, you should Eject(vRefnum), UnMountVol(vRefnum) to tell the OS to
forget that disk completely, then handle the Disk Insert Event for the target
disk (MountVol(drvnum)), do your copy, then Eject, Unmountvol the copy. Maybe
this will help!
Subject: RE: DS copier beta - problem (Re: Msg 14190)
Date: 26-OCT 11:44 Programming
That's not exactly the problem. It's the Eject itself that causes
sector two to be updated (written with old data). In fact I've
discovered that just mounting an HFS disk also causes sector two to be
written (with the volume write count field bumped by one). I think
I've got it solved by effectively nop'ing the _Write trap until I
want to do a write. That stops the unwanted updates which
occur on Mount and Unmount.
Thanks for your help.
Dave
Subject: RE: DS copier beta - problem (Re: Msg 14207)
Date: 26-OCT 13:43 Programming
As noted to you elsewhere:
Offline
copy using device-level calls to .Sony driver
Eject
Unmount
Date: 26-OCT 19:41 Programming
Are you using something like IAZNotify to make sure you don't lose control (as
by a bomb) with the _Write trap still jiggered?
peter
Subject: RE: DS copier beta - problem (Re: Msg 14225)
Date: 26-OCT 19:51 Programming
Thanks to Steve Brecher's suggestion, I don't have to 'jigger' the _Write trap.
To my mind, that's a relief just for reasons you suggest. BTW, Disk Dup+ in the
database must have had the same problems I had 'cause he also plays with the
_Write trap. I don't know if he uses IAZNotify, though.
Dave
Subject: PhoneNet/LaserWriter+ problems
Date: 25-OCT 16:35 Hardware & Peripherals
We recently installed PhoneNET in our offices. I have had trouble getting the
thing up and running smoothly (I am responsible for it) and am appealing to you
all for some help.
The problem is this: We can not get out LaserWriter Plus to come on to
the network with out causing problems. I notice that when I connect a
Mac to the net using the control pannel, the connection is rapid when
the LW is offline and very slow when it is on. Since the main reason
for the net is to print, we must have the LW on the network. I have
tried printing to the LW with a single Mac connected to it, and that
usually works (although it is still a little flaky sometimes). But
when I connect in the rest of the PhoneNet printing stops and the
status window in MacWrite just shows "status: preparing data" As soon
as I disconnect the other line to the LW (i.e. only on Mac is
connected to it) the printing continues. I have tried various ways of
connecting the LW on the net but without success. I bought MazeWars+
(to test the network, of course) and that works fine when the LW is
not on the net, but slows way down as soon as the LW is included. This
tells me that the network and the connectors are OK. SO what is the
deal with the printer? Is there someting special to get it to work OK?
And yes, I am using system 3.2 on all of the Macs, and have tried LW driver 3.1
and 3.1.1b. Help!! And THANKS! Our shop technician, who ran all of the wires,
and is very pro-IBM-clones is getting ready to pounce!!! -Doug (MADMACS)
Subject: RE: PhoneNet/LaserWriter+ problems (Re: Msg 14188)
Date: 27-OCT 08:51 Hardware & Peripherals
I wonder if it's a problem with the L.W. itself. Can you substitute AppleTalk
cabling for the PhoneNet cabling just for a test? Maybe you could get the
dealer to check out the L.W.?
Ric
Subject: RE: PhoneNet/LaserWriter+ problems (Re: Msg 14308)
Date: 29-OCT 22:21 Hardware & Peripherals
Thank you all for your suggestions. And yes, we did call Farallon and
they suggested that it is a problem with termination of the lines.
This was the case, apparently. They suggested one way of terminating
the lines and our technician said that it should be done another way.
(Sorry, but he did not tell me the details, I can find out if you are
interested.) Basically, if you leave the ends of long runs
un-terminated you get bad reflections that confuse the network. The
solution is to put a 120 Ohm resistor across the yellow and black
(PhoneNet) wires at the ends of the long runs. (This is and impedance
match that makes it appear as if the wire is infinitely long.) So once
this was done everything was working perfectly (my faith restored).
The technician, howver, is still stubborn (won't those IBM'ers ever
concede that the Mac can do anything well). When I pointed out that
or about $34 a node and the cost of phone wire, we had set up a local
area network that servers three floors and (presently) thirteen Macs,
he was not phased. I don't know much about the "token ring" and such,
but we didn't have to buy a thing extra, besides the connectors and
the wire. No boards or rewiring. And each member of the network
assigns itself a unique ID when it joins-- besides the reflection
problem it was basically hassle free. Now I can print anything that
(most) any Mac program can generate--at 300dpi and nearly WYSIWYG. Oh
well, you can't teach old dogs new tricks. Thanks again for your help,
-Doug
Subject: New Excel Version
Date: 26-OCT 00:20 Business Mac
When is version 1.05 of Excel available to owners?
Subject: Re: Re: Prob: interpreting Pascal to C -
Date: 26-OCT 03:17 MUGS Online
To: dlc%[email protected] (Dale Carstensen)
Subject: Re: Re: Prob: interpreting Pascal to C - HELP!
> The routine that has VAR thePt:Point where Inside Macintosh states only
> thePt:Point is MenuSelect ... Evidently Lisa Pascal and some other
> development environments correct IM's error in their "glue."
IM's description of MenuSelect(startPt: Point) is correct; the parameter is
passed by value; it is not a VAR parameter.
Subject: Computers and Medical Charts
Date: 26-OCT 16:26 Business Mac
The most amazing thing happened at the hospital yesterday. I was accused of
unethical behavior because I used my computer to prepare a conference for the
Department of Surgery!
Let me explain.... I am the Clinical Coordinator of the Department of
Surgery at a rural community hospital. This is a voluntary job, in
addition to my regular practice of surgery. My responsibilities
include the preparing of the mortality and morbidity conferences each
month, as well as trying to put together educational topics of
interest for the other surgeons. Having trained at a University
Hospital in Philadelphia, I enjoy doing this teaching.
In order to prepare for one of these conferences, I took my Tandy 100 to the
record room, and took my notes on it. When I got to the office, I plugged the
Imagewriter cable into the RS-232 connector on the back of the Tandy, and using
Smartcom II, loaded the information into the Mac for work processing, spread
sheeting, and graph creation.
Now, I am being accused of taking confidential information out of the
hospital in the form of patient records and doctors names! All I had
on the computer were my notes. The paranoid medical staff is afraid
that having this information in my "COMPUTER" is dangerous, in some
way. Since I consider my two computers just extensions of other work
tools that I use, I can't understand this. Would they be just as
paranoid if I used a legal pad to make notes instead of the computer?
By the way, the bylaws of the hospital allow for the use of records
for research, and I had permission from the President of the Medical
Staff to do the study in question.
Pretty amazing paranoia, huh? Do people really still fear computers this way?
Any physicians out there have similar experiences? Any legal advice?
Subject: RE: Computers and Medical Charts (Re: Msg 14213)
Date: 26-OCT 19:45 Business Mac
It might have something to do with Legislators, who tend to know even
less about computers than hospital staff. I've read some stories
about how some corporations are getting concerned about what J. Q.
Middlemanager is taking home to work on using his own computer after
downloading from the company mainframe.
peter
Date: 27-OCT 01:20 Business Mac
Yes, it's paranoid behavior, but no, it's not amazing, I'm afraid. In my
institution (UCLA Dept. of Radiological Sciences) most of the data used for
teaching and research is in "machine readable" form at one time or another.
Clearly there is a valid issue related to the removal of confidential patient
records from the hospital (I don't know what the regulations are there) but
these would apply equally to data whether in handwritten, printed or machine
readable form.
You didn't say exactly who is objecting to your work and on what
grounds, but it sounds like they don't have a very good idea of what
you're using the computers for. I can't give you legal advice though.
-Franklin Tessler, M.D.
Subject: Packbits
Date: 26-OCT 19:42 Programming Techniques
Does anyone know how to unpack something packed with packbits if you dont kow
the original #bytes packed? thanks jim
Subject: News from the Meadow
Date: 27-OCT 06:03 MUGS Online
In the Friday, October 10, 1986 edition of The Cincinnati Enquirer,
Lise Olson of the Gannett News Service described the activities of a
Livonia Michigan computist who illegally reproduced several of Berke
Breathed's "Bloom County" cartoons, featuring the consumate hacker
Oliver Wendell Jones, in an underground newsletter named
Telecomputist. The Washington Post Writer's Group, which owns the
strip's copyright, asked the Telecomputist to "cease reproduction of
'Bloom County' comic strips or images of 'Bloom County' characters."
Andrew S. Rosen, counsel for the Washington syndicate, "decided not to
seek the death penalty in this situation" but said that the
reproduction was a "serious matter."
Jones and his "Banana 6000" personal computer are popular symbols
among Apple Macintosh enthusiasts. According to Al Leeds, sales
manager of the Washington group, small publications can legally
reprint the strip for as little as $6.50 a week. In addition to
flouting the copyright laws, Telecomputist published such information
as Secret Service radio frequencies and classified goverment phone
listings - the kind of thing that gives hackers a bad name. Breathed
is sympathetic to hackers but not to rip-off artists. He warned: "If
we catch you, we're goin to nail your toes to the wall and hang you
upside down, pull out your
tongue and dip it into a nest of red ants.
Let this be a warning."
Subject: RE: LightSpeed C/Loadseg hangs! (Re: Msg 935)
Date: 27-OCT 00:46 Programming Techniques
The same thing has happened to me. However, it had creamed the
MacTraps library. It had put a $0000 across an instruction in FSRead,
causing all sorts of weird crashes at non-sequitor locations. (It had
creamed the argument popping cleanup of the stack). My only resort was
to replace MacTraps from a master. I have never been able to reproduce
the problem.
Subject: RE: LightSpeed C/Loadseg hangs! (Re: Msg 938)
Date: 27-OCT 23:44 Programming Techniques
Just to keep people informed, I recompiled my program from scratch (re loading
all 5 libraries and 30-odd source files...). No change in functionality -- it
still hangs in loadseg. It looks like it isn't a corrupted application file
(sigh). I AM amazed that LSC could compile 55,000 lines in about 35 minutes or
so -- now, if it only worked! (grin!)
chuq
Subject: RE: LightSpeed C/Loadseg hangs! (Re: Msg 940)
Date: 28-OCT 02:07 Programming Techniques
Just a thought -- check the total amount of Initialized data that you
have. From memory, I don't think it allows more than 31.?k. Also check
your segment sizes. The Loadseg patch is for the CREL stuff -- it
relocates certain things within CODE segs as they are brought in. Also
check that 'ResLoad' is NOT False at a call to another Segment.
Subject: MS Word 3.0 for the Mac
Date: 27-OCT 20:14 Bugs & Features
According to the Wall Street Journal, Microsoft was supposed to unveil MS Word
3.0 for the Mac today. List price: $395. It supposedly will enable Macs and
PCs to easily share documents and word processing tasks. It enables documents
and files produced on the Mac to be edited on the PC and vice versa.
Brian
Subject: RE: MS Word 3.0 for the Mac (Re: Msg 14259)
Date: 28-OCT 08:16 Bugs & Features
Yes, InfoWorld and ComputerWorld also had short pieces on it. They
said that it would run with TOPS.
Ric
Subject: RE: MS Word 3.0 for the Mac (Re: Msg 14277)
Date: 28-OCT 20:01 Bugs & Features
Brian, unless we read different articles, they were just _announcing_ the
product today, even though it will not be shipped until early 87. (January).
MS is heralding some great vaporware although the final product, which
is said to be able to be read directly by IBM and Macintosh versions
of Word, looks hot.
Style pages, better headers, and more make it seem to still be the
only choice (or at least it will be the only choice) in WPs for the
Mac. Heres a hot rumor... Lotus' manuscript, recently announced for
the IBM, might be making its way over to the Mac. Hmm...
Josh
Date: 28-OCT 22:57 Bugs & Features
What The WSJ didn't say is that Word 1.05 can trade files with the MS-DOS
version already.
Lofty
Subject: RE: MS Word 3.0 for the Mac (Re: Msg 14295)
Date: 28-OCT 23:23 Bugs & Features
The reports indicated that even the new version would not be able to show
multiple columns on the screen, as WriteNow can...
Ric
Subject: RE: Word 3.0 -- A Mirage? (Re: Msg 14275)
Date: 28-OCT 15:29 Business Mac
We've had Word 2.0 for quite some time now. We demoed it at the ICONtact party
in front of a few users (DDunham, MacIntouch, MicMac) etc..
The news we have is that the program will NOT be released until 1987.
Rich.
Date: 29-OCT 01:23 Business Mac
I was excited when I saw the InfoWorld article too, until I found out that it
was based on them calling BMUG last week.
-- Raines Cohen
BMUG, Inc.
also known as VaporRumorMongers, Anonymous
Subject: Re: Lisa to Mac compatibility
Date: 27-OCT 23:03 Network Digests
To: [email protected] (Rich Amber ) Re: Lisa to Mac compatibility
If you want to read the Lisa programs for Macintosh consumption, I'm presuming
the programs are Pascal and that you have the Lisa Pascal Workshop running on
the Lisa.
If you have one of the Unix systems, or the Lisa Office System only,
think about running terminal programs with the Mac ImageWrite cable on
the serial ports.
With the Lisa Pascal Workshop, you can read/write Macintosh-format diskettes
with the Maccom utility. This is available through the Software Supplement to
the Pascal Workshop, not on the original Workshop 3.0 disks.
There's also a Transfer utility in the Workshop which can work as a basic
terminal program on the Lisa side for transferring files to the Macintosh.
Finally, MacWorks lets the Lisa run Macintosh software, but removes its ability
to run or read Lisa programs.
Have fun with it..I sure do.
Laird J. Heal
Subject: Weird font problem
Date: 28-OCT 07:40 Business Mac
What is happening here? I am trying to capture some Vax screen images. I have
Mac Terminal, Draw, and Word in Switcher on a Mac+ and a DataFrame 20. I am
representing the screens in 10 point Courier. I get the screen with Terminal,
select the text, Copy it, switch to Draw, and Paste it.
Now, here's the fun part: The text I paste arrives in Draw in 10 pt Courier,
as that is the default font I've set up. However, the size of the characters
(horizontally) is not the same as the size of 10 pt Courier just typed into
Draw, or pasted from Word. The text copied from Terminal is shorter than the
same characters from the other sources. But it is all the same font and
pointsize, supposedly. The discrepancy is small--about 31 characters from
terminal equals 30 typed direct.
Anybody have a clue about why this is happening?
Subject: DrawMenuBar() tidbit
Date: 28-OCT 02:36 Programming Techniques
Don't call DrawMenuBar() from inside a routine called by MenuSelect() -- set a
flag somewhere to tell your idle task to do it. Not only is this more
efficient, but you will not find mysterious vertical patches of desktop grey
appearing inside the menu bar.
peter
Subject: alarm clock menu blink
Date: 28-OCT 02:38 Inside Mac
Does anyone know how to cancel the blinking apple menu once the alarm
has gone off? I've figured out how to set the alarm (it's the 0x8000
bit in the SysParam.volClik word). I've read TN87(?) "Blinkin' Note"
which makes a passing reference to a "time to blink" flag but
naturally doesn't say where it is and what it should be set to...
Subject: RE: TeX (Re: Msg 14274)
Date: 28-OCT 22:29 Mousing Around
Ya, that's the only problem I've had with TeX, though A-W's version for the
Mac is becoming more "Macish" with each release.
Without a full bank of very scrollable menus, however, one couldn't really
hope to allow for all of TeX's options in the Mac interface...it virtually
allows control over the placement of each letter to within a tiny space. And
while the control codes can seem a bit arcane, they do allow for a fantastic
WP or layout construction set. If you don't like "\font\term\cmr10
scaled\magstep2"
you can always define /doit to mean the same thing.
So, while TeX isn't the ULTIMATE typesetting program (the one that sucks my
thoughts out of a wire coming from my left ear, and lays them out in accordance
with some warped vision I have in mind), it's not as bad as it sounds (at
least, after you play with it for a few weeks).
Alf
Subject: RE: INFO-MAC Digest V5 #2 (Re: Msg 14282)
Date: 28-OCT 23:09 Network Digests
Two comments on the INFOMAC stuff.
1. You can save Page Setup defaults as a WORD glossary entry.
Not quite as nice as changing the default, but better than going to
the Page Setup dialog.
2. Tom Mackie (Princeton MUG) is keeping an up-to-date list of Mac
software versions. He posts from time to time on CIS, maybe GENIE too.
Lofty
Subject: RE: INFO-MAC Digest V5 #2 (Re: Msg 14296)
Date: 28-OCT 23:22 Network Digests
Lofty,
How do you save Page Setup in the Word glossary?? Can it handle landscape
vs. portrait page setup?
Ric
Subject: Word / WriteNow
Date: 28-OCT 23:44 Business Mac
Do you have a working review copy of WriteNow? What are your first impressions
and how does it compare with Word...
josh
Subject: Dataframe Squeal
Date: 29-OCT 01:11 Hardware & Peripherals
Hi Yall...
Any one had experience with their Dataframe 20 producing a high pitched
squealing sound on start up. Usually last for jh just a few seconds.
I was told that it was the antistatic brush. Also to expect some major crashes
in possibly six months ?
RJ
P.S> So much for the new disk drives for the dataframe.
Subject: RE: Dataframe Squeal (Re: Msg 14305)
Date: 29-OCT 21:50 Hardware & Peripherals
On a related high pitched note, my DataFrame has started to ignore the power
switch on turn on (anyone who suggests foreplay is asking for it...). I seem
to recall some notes about that symptom either here or in Usenet. Anyone recall
what the cure was?
Alf
Subject: DiskTimer results
Date: 29-OCT 03:59 Hardware & Peripherals
These are reported results from the DiskTimer program as of Oct. 28, 1986.
DiskTimer measures performance on large (32KB) data transfers and on access
time (seeking, head movement). The results are independent of the file system,
amount of free space, System and Finder versions, etc. There is no direct
translation of these results to perceived performance in ordinary Mac usage.
Multiple results from the same drive by the same submittor which vary by not
more than 5% have been combined into one report by taking the best result
for each of the three tests. Where three or more reports from different
submittors on the same drive were available, I have omitted those having
results on all three tests which fell between the best and worst shown below
for that drive.
Additional reports are welcome on hard disks not shown below or those which
have only one report so far. Please disconnect Appletalk or other networks for
the test, since network activity generates interrupts that temporarily suspend
execution of the disk driver software.
----- time in seconds -----
100 32KB 100 32KB 80 1MB
Model, Vendor [Note] Reads Writes Seeks Reported by
AST 2000, AST Research 25.7 25.5 4.7 Bill Steinberg
AST 4000, AST Research 24.8 24.0 1.4 Frank Brooks
Bernoulli Box 10+10 SCSI, Iomega 26.4 26.5 3.7 Netman, MacInTouch
DataFrame 20, SuperMac 33.6 33.5 6.9 Robert Wiggins
DataFrame 20, SuperMac 33.6 33.3 7.1 RONB/Delphi
DataFrame 20, SuperMac [1] 29.0 29.1 4.2 DWB/Delphi
DataFrame 40, SuperMac 13.4 13.7 3.8 Norman Fong
Easy Drive 40MB, DC Systems [2] 56.4 59.5 3.7 Tim Smith
Easy Drive 40MB, DC Systems [3] 18.2 42.3 3.7 Tim Smith
Easy Drive 40MB, DC Systems [4] 24.2 24.4 3.6 Tim Smith
Hard Disk 20, Apple 115.6 130.9 6.1 Steve Ellett
Hard Disk 20, Apple 162.5 166.7 6.1 Robert Wiggins
HardMAC+ 20MB, CMC 36.6 36.8 3.6 Pete Adams
HardMAC+ 20MB, CMC 41.8 42.7 3.7 Joseph DiGangi
HardMAC+ 20MB, CMC 18.3 18.5 3.6 C. McConathy, CMC
HD20SC, Apple (SCSI) 20.5 20.5 3.8 Norman Fong
HD20SC, Apple (SCSI) 20.6 20.6 3.7 Brian Hall
HD20SC, Apple (SCSI) 20.5 20.6 3.9 P. Williams, Apple
HyperDrive 10 (64K ROM), GCC [5] 130.8 114.0 6.1** Frank Brooks
HyperDrive 10 (64K ROM), GCC [5] 132.1 131.8 5.4** Harry Conover
HyperDrive 10 (64K ROM), GCC 25.1 25.1 7.8** L. Randy Lee
HyperDrive 20 (64K ROM), GCC 26.5 25.0 2.9 Steve Ellett
HyperDrive 2000, GCC 14.8 12.9 2.9 Harry Starr
HyperDrive FX20 (SCSI), GCC 20.5 29.6 3.8 Tom Negrino
HyperDrive FX20 (SCSI), GCC 20.5 30.5 3.8 Harry Starr
Direct Drive 20, Jasmine 24.6 120.5 3.4 Jim Clark
LoDOWN 20MB, LoDOWN 16.5 18.2 4.0 David Dunham
LoDOWN 20MB, LoDOWN 16.6 16.9 3.8 Steve Ellett
LoDOWN 20MB, LoDOWN 18.4 18.3 3.9 Michael Klickstein
LoDOWN 20MB, LoDOWN 16.5 17.0 3.5 Bill Steinberg
Mac20, Paradise (serial port) 226.4 227.1 6.7 R. W. Zehr
MacBottom (serial port), PCPC [6] 68.0 112.7 6.4 Joseph Cortney
MacBottom (serial port), PCPC [7] 68.4 113.9 10.1 Joseph Cortney
MacBottom (serial port), PCPC 68.0 112.8 9.1 Steve Ellett
MacBottom (serial port), PCPC 68.8 113.6 9.3 Robert Hafer, BCS
MacBottom HD21 (SCSI), PCPC 214 21.6 4.9 Steve Ellett
MacBottom HD21 (SCSI), PCPC 21.6 22.1 4.9 Linda Kaplan
MacBottom HD21 (SCSI), PCPC 21.7 21.6 4.8 Bill Steinberg
MacDrive, Tecmar 100.2 111.3 5.9 Chip Nicolais
Magic 20, Rabbit Industries 18.4 42.8 3.8 Larry Halff
MicahDrive 20 AT, MICAH 8.2 8.5 8.2 Rob Hahn
MicahDrive 20 AT, MICAH 8.2 8.2 7.2 Ted May
OverDrive 20/Prodigy 4, Levco 51.4 142.9 4.7 Harry Starr
Photon 20, Warp Nine Engineering 23.4 28.7 3.9 Duane Williams
ProApp20, ProApp 13.3 24.0 3.3 L. Randy Lee
S-20+, Peachtree Technology, Inc. 21.6 21.6 4.9 L. Randy Lee
S-20+, Peachtree Technology, Inc. 21.5 21.5 4.8 Dolph McCranie
Notes:
[1] 512E with Levco SCSI add-on and MonsterMac RAM upgrade
[2] 1:1 interleave (as shipped)
[3] 3:1 interleave
[4] 4:1 interleave
[5] These apparantly anomalous results are unexplained.
[6] LaPine drive.
[7] MicroScience drive.
** On HyperDrives, the seek test provides meaningful results only when run
from a drawer which is contiguous for more than 1MB. Whether this was
the case for these results is not known, but the results suggest it
was not the case.
End of Delphi Mac Digest
