Re: MacTerminal, Emacs, and Dec 20s
Subject: Re: MacTerminal, Emacs, and Dec 20s
Date: Mon, 28-Jan-85 03:33:22 EST
Article-I.D.: uw-beave.611
Posted: Mon Jan 28 03:33:22 1985
Date-Received: Tue, 29-Jan-85 05:48:55 EST
Lines: 30
Carl,
your problems seem to be way out of line with what I have encountered
with the Emacs-Mac combination. sounds as if you may be able to improve things
somewhat by changing some parameters both on the R20 and on the Mac-side.
Let me jsut tell you the way I am set up:
on the 20 I use terminal type VT100, in EMACS I use M-X Set Terminal Type$VT100
(well, actually, I have my EMACS.INIT set up to use this as default when on a
dial-up line)
On the Mac-side, I use VT100 in ANSI mode,8bits, no parity, XON/XOFF enabled
(the last is very important when using 9600Baud lines) notice that I suspect
your problem to be caused by not having XON/XOFF enabled. the Mac does not
seem to be able to keep up with even 1200 Baud without it. An undesirable
side-effect of XON/XOFF is that ^S, the Emacs-SEARCH command, and ^Q the
Emacs QUOTE command are misinterpreted by the Mac. when in EMACS using ^S to
SEARCH, Mac thinks that you just wanted to stop output, so nothing is displayed
further until you type ^Q. Reason seems to be that the screen display can't
keep up with the characters coming "down the pipe", so MacTerminal assumes
when it sees a ^S, you want scrolling to stop NOW, rather than display every-
thing already received into the buffer. So rather than just passing the ^S
to the main-frame to decide what to do with it, MacTerminal tries to "second
guess" the user. Sigh ....makes using EMACS a real drag. try it at 9600
Baud sometimes, and watch how Mac and 20 get confused when MacTerminal sends
a ^S to tell the 20 to stop sending stuff - and Emacs on the 20 thinks you
jsut typed a SEARCH-command. Curse ......
