MacPaint -> bitmap filter, in C
Subject: MacPaint -> bitmap filter, in C
Date: Thu, 2-Aug-84 22:22:22 EDT
Article-I.D.: uw-beaver>.1388
Posted: Thu Aug 2 22:22:22 1984
Date-Received: Sat, 4-Aug-84 02:16:39 EDT
Lines: 137
The following program allows printing of MacPaint documents on devices which
accept raw bitmaps as input. It provides for simple scaling-up of the
images to accomodate the typical 200-300dpi resolutions of electrostatic
plotters and laser printers. It requires a machine with a 32 bit integer,
but should be very portable otherwise.
/* MacPaint format -> bitmap filter
P. Rowley, U. Toronto, July 30, 1984.
peterr%toronto@CSNET-RELAY
This program reads a standard MacPaint document on the standard input
and produces a bitmap file on the standard output. The bitmap is
some magnification of the MacPaint 576 (horiz) x 720 (vertical) encoded
image, possibly with horizontal 0 padding.
The specific bitmap format is determined at compile time,
for the sake of efficiency.
#include
/* The manifests define the output bitmap format as follows:
The bitmap is OUT_HORIZ_SIZE bytes wide and 720*OUT_VERT_MUL tall,
with each Mac pixel translated into a OUT_HORIZ_MUL x OUT_VERT_MUL
rectangle. There are OUT_HORIZ_PAD bytes of left margin on every
output scan line.
The following restrictions apply to the manifests:
OUT_HORIZ_SIZE >= OUT_HORIZ_PAD + 72 * OUT_HORIZ_MUL
OUT_HORIZ_PAD >= 0
OUT_HORIZ_MUL = 1, 2, 3, or 4
OUT_VERT_MUL >= 1
Sample values (for a Versatec plotter): 264, 24, 3, 3
#define OUT_HORIZ_SIZE 264
#define OUT_HORIZ_PAD 24
#define OUT_HORIZ_MUL 3
#define OUT_VERT_MUL 3
char in_line[72], out_line[OUT_HORIZ_SIZE];
int xlat[256];
main() {
int i, j;
/* initialize tables and buffers */
init();
/* read and discard 512 byte header */
for (i=0; i 127) count -= 256;
if (count >= 0) { /* run of raw bytes */
count++; /* # of bytes to read */
while (count--)
in_line[in_pos++] = getchar();
else { /* run of repeated byte */
count = -count+1; /* repetition factor */
data_byte = getchar(); /* byte to repeat */
while (count--)
in_line[in_pos++] = data_byte;
write_scan() {
int i, j, outword;
/* prepare output scan line:
OUT_HORIZ_PAD 0's,
72 * OUT_HORIZ_MUL data bytes,
enough 0's for a total of OUT_HORIZ_SIZE bytes
/* leading and trailing 0's are in out_line by default */
j = OUT_HORIZ_PAD;
for( i=0; i> 24) & 255;
#endif
#if (OUT_HORIZ_MUL >= 3)
out_line[j++] = (outword >> 16) & 255;
#endif
#if (OUT_HORIZ_MUL >= 2)
out_line[j++] = (outword >> 8) & 255;
#endif
out_line[j++] = (outword ) & 255;
/* output the scan line, OUT_VERT_MUL times */
for( i=0; i<OUT_VERT_MUL; i++ )
for( j=0; j<OUT_HORIZ_SIZE; j++ )
putchar( out_line[j] );
init() {
int bits[8], i, j;
/* initialize translation table */
j = (1<<OUT_HORIZ_MUL) - 1;
for( i=0; i<8; i++ ) {
bits = j;
j *= (1 << OUT_HORIZ_MUL);
for( i=0; i<256; i++ ) {
if( i & 1 ) xlat = bits[0];
else xlat = 0;
if( i & 2 ) xlat += bits[1];
if( i & 4 ) xlat += bits[2];
if( i & 8 ) xlat += bits[3];
if( i & 16 ) xlat += bits[4];
if( i & 32 ) xlat += bits[5];
if( i & 64 ) xlat += bits[6];
if( i & 128 ) xlat += bits[7];
