SnagWindow 1.0.2
SnagWindow 1.0.2
Download: http://archive.info-mac.org/cfg/snag-window-102.hqx
SnagWindow 1.0.2 automates the capture window command (caps lock, command,
shift, 4) in MacOS 8.5 and higher. The user can choose how many caps
(pictures of windows) to make and what interval.
Updated for OS 9. Requires OS 8.5 or higher. FREEWARE.
