Sherlock Nobanners for Mac OS 9.1
Download: http://archive.info-mac.org/cfg/sherloc ... ers-91.hqx
2001-08-01
This is a simple ResCompare patch that removes all banners from Sherlock
version 3.0.2, included with OS 9.1. The patch will only work with
Sherlock 3.0.2. To remove banners from earlier versions, download the
other editions of Nobanners.
Most banner programs simply alter the search plugins in your system
folder; this one modifies three resources in the Sherlock application
itself, displaying only gray space instead of an obtrusive banner. If
you would rather make the modifications yourself, you can use Metrowerks
Constructor.
Use this program at your own risk. I am not responsible for the
consequences. This program is free and may be distributed on all media
for non-profit use only. For-profit users should contact the author.
