Sherlock is Apple's newest technology in OS 8.5. It allows you to quickly
search internet sites directly from the finder. The Sherlock Amazon
plug-in will allow you to add Amazon.com to the list of sites you can
search from your finder making it easier and more conveinent to search for
books or music online.
The plug-in requires Sherlock and Mac OS 8.5 or greater.
