Sherlock 2 no ads 9.0 patch
Download: http://archive.info-mac.org/cfg/sherloc ... ads-90.hqx
Sherlock 2 Ad Remover Patch for Mac OS 9.0
This little patch for the OS 9.0 version of the Sherlock 2
application will remove the banner ads from Sherlock 2, sparing you
from horribly ugly animated gif banners.
Created by David Caldwell 10/21/99
Email: [email protected]
Web: http://www.indigita.com/david/sherlock/
