This patch removes Sherlock 2's brushed metal surface. Adds new 3-D
Copeland style icons. Removes white channel windows and replaces them
with Mac buttons which depress when selected.
Directions for use: Double click patch, find your original version of
Sherlock 2 and apply patch. A new modified version of Sherlock will be
created. This will not delete your original Sherlock 2.
