Sesame 2.2 - Password protection for your Macintosh
Download: http://archive.info-mac.org/cfg/sesame-22.hqx
Sesame is a simple but effective safety tool for your Macintosh or
compatible computer. This application prevents unauthorized access by
requesting a password whenever it is launched (for instance at startup).
Security options will prevent a power user from inactivating Sesame at
startup or forcing it to quit. And even if a snooper uses a System floppy
disk to start up, Sesame will protect you: it can automatically hide the
files of folders you have selected; without the right password, they will
remain invisible. You can easily personalize the presentation of the
password dialog with your own icon, picture or text, and Sesame even
incorporates a screen saver. And finally, a nice touch for site
administrators: you can create an administrator password in addition to
your individual password.
Sesame requires System 7 or higher and is fully compatible with Mac OS 8.
Sesame comes with a detailed manuel, and an installer program that will
install everything for you.
Shareware $10 (site license: $100, world-wide licence: $400).
*** This is the US version of Sesame. French, German and Japanese versions
are also available. ***
Sesame is ©1996-1998 Bernard Frangoulis.
