Subject: Re: Icons
Date: Wed, 21-Nov-84 21:18:43 EST
Article-I.D.: uw-beave.2308
Posted: Wed Nov 21 21:18:43 1984
Date-Received: Wed, 28-Nov-84 03:34:36 EST
Sender: yenbut@uw-beave
Lines: 25
From: decvax!genrad!mit-eddie!godot!harvard!gcc-opus![email protected] (Brad Parker)
In article you write:
>From: cornell!kevin@lasspvax (Kevin Saunders)
>This ought to work, though I've not done it: using the Resource Mover (I
>assume you've got a copy of this) open the document created by
>the Icon Editor, copy it into the clipboard, and then paste it into
>the target file. There! The spirit of *simplicity*.
>How utterly Macish. . .
>Hope it works,
>Kevin Eric Saunders
I think this is a bit simplistic. You have to create an icon list resource
with the resouce compiler (RMAKER?) - this is a list of two icons (Type ICN#)
the first of which is the icon, the second is a mask the finder uses to "gray
out" the icon. Then, you have to place the icon list resource into the
application the the rmover.
Some fun huh?
J Bradford Parker
uucp: siesmo!harvard!gcc-opus!brad
"Their is no language in our lungs!"
