Replace! 1.0.1
Replace! 1.0.1
Download: http://archive.info-mac.org/cfg/replace-101.hqx
When you save a file and get the "Replace existing ?" dialog,
this extension will make the Replace button, rather than the Cancel button,
be the default. Requires System 7 or later; updated for Mac OS 8.5. Will
not slow down your Mac. Freeware.
-- James W. Walker
