Download: http://archive.info-mac.org/cfg/pw-disk-guard-161e.hqx
You need to have:
MacOS 7.5.x
AppleScript (You have it unless you uninstalled it.)
BBEdit Lite
What is it?:
When installed as directed, PW DG asks the user to enter a password. If the
password is incorrect than the computer shuts down.
Some features:
The password is saved somewhere on your computer where no one can access it
in an encrypted file that has no creator app or file type so it cannot be
opened when double clicked on. You set the password yourself. When you type
the password in the pw setter program, it shows up as bullets. To view the
password you set just open the pw viewing program. Be sure to hide this so no
one can get to your password.
Each application requires close to no RAM at all.
ShareWare:
Register for $10.00 using Kagi and get new versions for free.
To get the most recent version of PW DG go to:
http://home.maine.rr.com/rabba/pwdg
or
http://www.macupdate.com Located in the Utilities/Security section.
