PRAM Inspector 1.1
PRAM Inspector 1.1
Download: http://archive.info-mac.org/cfg/pram-inspector-11.hqx
% About PRAM: Various settings need to be preserved when the Macintosh
is off so they will still be present at the next system startup. This
information is kept in parameter RAM (PRAM), which is stored in the
clock chip together with the current date and time setting. The clock
chip is powered by a battery when the system is off, thereby preserving
all the settings stored in it. PRAM Inspector lets you see exactly what
is stored in your PRAM, so you can detect PRAM problems by yourself.
% DISTRIBUTION INFORMATION: PRAM Inspector v1.1 is distributed as
freeware. You may upload this program to any online service, bulletin
board, network, or the Internet, as long as the program is not modified.
You may NOT make copies of this program for any commercial purpose.
You must get permission to include this program on CD-ROM, floppy disk,
etc.
http://pages.infinit.net/trottier/
