Power Menu 2.2.3J - Japanese Version
Download: http://archive.info-mac.org/cfg/powermenu-223-jp.hqx
This is the Japanese version of the PowerMenu package.
PowerMenu is a utility that adds powerful commands to your contextual menu
if you are running MacOS 8 or better. If you are running the older
Macintosh System 7, PowerMenu adds a contextual menu to your system so you
can still use this innovative feature without upgrading to MacOS 8.
PowerMenu's contextual menu commands let you do all these operations with a
single click:
*Open files straight into any application. If the application you want to
use isn't running, PowerMenu automatically launches it for you.
*Move, copy or make an alias of files straight into target folders of your
choosing.
*Quickly open commonly used files or launch any application.
PowerMenu also provides these handy features:
*"File Copy and Paste", a unique feature that makes manipulating files much
easier. With File Copy and Paste, you can "pick up" files and "drop" them
into another folder without dragging and dropping. You can even "gather"
many files from different locations and copy or move them all to a single
target folder with just a few clicks or keystrokes!
*A pop-up menu, accessible from any application, that lets you quickly open
or launch your commonly used files and applications with a single click.
PowerMenu gets the job done faster with:
*Fully hierarchical menus to allow you to group items into submenus for
even faster access.
*Multithreaded operation; PowerMenu rebuilds your menus in the background
while you work, so even very large menus appear instantly.
*Takes full advantage of MacOS 8 features, but is still fully compatible
with System 7!
Changes in version 2.2.3J: Corrects a startup bug and greatly accelerates
the drawing of custom icons under MacOS 8.5.
