Passord Protect Folders 1.4.7 demo
Download: http://archive.info-mac.org/cfg/passwor ... olders.hqx
Password Protect Folders 1.4.7 demo - Have you ever wanted to make sure that
your most personal folders are kept from prying eyes? Then this AppleScript is
for you! Password Protect Folders (PPF) is designed to passsword protect
personal folders on local or remote disks. One or more folders are dragged and
dropped onto the AppleScript, assigned a user defined password and then made
invisble. Folders are re-made visible by relaunching the application, selecting
one or more folders in a single dialog box and then entering the correct
password. A text file is maintained to keep track of the locations of all
currently hidden folders. Offers a level of security sufficient for most home or
business uses. Version 1.4.7 adds bullets during password specification (by
popular demand!)
