Noflet 2.2.1 (formerly known as Teflon)
Post by Info-Mac » October 23rd, 1998, 9:00 am
Download: http://archive.info-mac.org/cfg/noflet-221.hqx
Mac OS 8 introduced a new feature called "sticky menus," where the menus
would stay down after the user clicks in the menu bar or on a pop-up menu.
This is a change from the way menus worked in previous versions of the
system software, where the menus would always go away after the user let go
of the mouse button. Noflet is a control panel which is designed to
disable or adjust this dubious "feature." Additionally, it includes an
option to have menus automatically open whenever the mouse pointer is over
the menu bar, with no clicking required.
Noflet 2.2.1 changes the name of the program, at the request of E.I. du
Pont de Nemours and Company, which owns the "Teflon" trademark.
Noflet currently runs properly only under Mac OS 8.0 and 8.1. This version
is NOT compatible with Mac OS 8.5. An 8.5-compatible release will be under
development as soon as I obtain a copy of Mac OS 8.5.
Noflet is freeware and may be included on the Info-Mac CD-ROM. This file
should replace all previous versions of Teflon.
