MATM 1.0.2
MATM 1.0.2
Download: http://archive.info-mac.org/cfg/matm-102.hqx
If you've ever wondered how the Macintosh OS has partitioned your memory,
More About This Macintosh (MATM) is for you. MATM graphically shows your
current memory configuration, including empty blocks. This will tell you
at a glance which applications you need to quit in order to run that
memory-hogging program. It also gives other information that can be very
helpful if you need to know more about your configuration, such as
Macintosh model, processor type, and processor speed.
Kevin Tieskoetter
Albatross Productions
Kevin Tieskoetter
Software Prestidigitator, MetaCreations (www.metacreations.com)
Email address: [email protected]
Home Page:
