Mac Restart 2.1 ppc
Mac Restart 2.1 ppc
Download: http://archive.info-mac.org/cfg/mac-restart-210-ppc.hqx
Mac Restart is a reliable utility to improve efficiency of critical
Macintosh servers. If you run a Mac server you will have benefit using
Mac Restart. Restarting automatically, as example during the night, will
improve efficiency of the server. Even Unix servers use this method! Mac
Restart allows you to select the time/day when automatically restart
your Mac using a weekly plan and which method to use between 'Soft
Restart' and 'Hard Restart'. A flashing black dot on the right of Mac
Restart window will inform you the computer is going to restart. If Mac
Restart is in the background it will use Notification Manager, flashing
in the right of the menu bar, to inform that restart is coming. New in
this version : status window can be closed with automatic opening
approaching restart.
Features:
Small Ram requirement.
Doesn't hog the cpu when in background.
Soft Restart and Hard Restart.
All setting customizable.
Restart Approaching flashing dot
Util menu for a better setup.
All settings in one dialog
Weekly plan of restart.
Runs on System 7 and System 8.
This is the new version 2.1.0
TENSION SOFTWARE HOME PAGE:
Available both in 68k version and PPC
* Inclusion in Shareware Disk & CDROM is Authorized *
