MMDemo358.hqx (Mac Manager Demo v3.5.8)
Download: http://archive.info-mac.org/cfg/mac-man ... mo-358.hqx
Mac Manager provides desktop security, accountability, personal folder
management with disk quota, e-mail, screen saver with screen lock, and
virus protection all in one package. Users are limited to launching and
using applications, documents, control panels, and Apple Menu Items made
available through customized setups. Users can be restricted on Open and
Save actions to a floppy disk, personal folder, drop folders, open only
folders, and public folders. Mac Manager¹s interface totally emulates
Finder. Users can set custom desktop styles such as 3-D, Hi­Tech, or
Kids, and can perform multiple simultaneous file­copy operations.
Mac Manager is easy to use and simple to set up using guided
step­by­step on screen instructions. Mac Manager can control a user¹s
daily time, printer pages, inserting of floppy disks, and the ejecting
of CDs. A detailed log tracks ALL user activity, including time on
applications. A hard disk encryption utility restricts all access if
booting from another System disk.
Mac Manager is the perfect solution for homes, businesses, and schools
where computers are shared. Private files and data can be kept secure
and away from prying eyes. No more loss of data, resetting control
panels or chooser settings, reinstalling system software or trying to
find files.
Mac Manager is compatible with System 7.0­7.6 and is Accelerated for the
Power Macintosh. Site license editions support and take full advantage
of all Macintosh networks, and include a complete set of network
management tools provided by the application Net Manager. Tools to
control all networked computers from any workstation include shutdown,
restart, launch, quit, copy, delete, rebuild desktop, mount, unmount,
empty trash, set clock, lock keyboard, login, logoff, and more.
Demo Differences:
1) The demo only runs for one hour each day. At the end of the
hour, the demo automatically quits and returns to Finder. Other running
applications are unaffected. 2) The demo does not use Mac Manager¹s
disk protection features that prevent users from booting with another
system disk or holding down the Shift key to bypass extensions. 3)
Each group is limited to five users and only six groups are allowed. 4)
The hard disk encryption option is not included. 5) Network
management tools (included with all site license versions) are not
included. 6) Mail Manager is not included.
ELS,Inc. 5200 NW 43rd Street, Suite 102-323
[email protected] Gainesville, FL 32606 http://www.elsinc.com
(352) 375-0558 Voice (352) 375-5679 FAX
