Quit CSM 2.2 J - Japanese Version
Download: http://archive.info-mac.org/cfg/mabasof ... -22-jp.hqx
This is the Japanese version of Quit CSM.
Quit CSM is a Control Strip module which lets you quit applications
without having to activate them: you can quit a single application,
the background applications and all running applications. It also
allows you to quit and restart the Finder and quit background-only
applications and displays memory information (application sizes and
largest unused memory block).
For more info visit http://www.mabasoft.com/quit.html.
System Requirements
Control Strip, Extensions Strip (2.0bx or higher), WorkStrip and
ACTION GoMac can be used as module host.
What's new in Quit CSM 2.2?
- The procedure which calculates the largest unused memory block has
been rewritten: the value displayed by Quit CSM is now always
accurate.
- Quit CSM can now also show the free RAM in the memory bar. The
Display Free Memory option can be selected in the Preferences pane of
the Quit CSM Settings control panel or, directly from the Control
Strip, using the Memory popup menu.
- In the presence of more module hosts Quit CSM is now capable of
correctly recognizing from which module host it is running, so that
it can behave accordingly (some Quit CSM options and abilities depend
on the module host's features).
- Quit CSM can now quit applications not supporting AppleEvents with
WorkStrip too.
- Some minor bugs have been fixed.
