Date: Tue, 8 Oct 96 11:17:48 PDT
Reply-To: [email protected]
Subject: Info-Mac Digest V14 #236
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Tue, 8 Oct 96 Volume 14 : Issue 236
[*] Font Clerk 6.0.2
[*] Font Gander 1.0.3
[*] TidBITS#348/07-Oct-96
(Q) WGS 7250 and 1710AV ??
603e vs 604
[Q] Straight-through serial cable
Empty font suitcases
Ethernet time synchronisation
FontBox 2.0 Problems
Help with MAC LC
How to Downgrade to 7.5.3
Info-Mac Digest V14 #227
Mac to DOS
Quicktime Musical Instruments Program/Patch Changing?
RAM-pig
Seeking Word-counting Program
Senior Math Educational Software
starting up from zip disk?
Gordon Watts, Liam Breck, Adam C. Engst, Demitri Muna, Mike O'Bryan
Files for inclusion:
and upload it to:
all of this info and more!
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V14 #236"
Date: Mon, 7 Oct 1996 03:29:51 -0700
Subject: [*] Font Clerk 6.0.2
This is the latest update to Font Clerk. it fixes a color display problem
that surfaced on some PowerMac models (7200,7600).
Font Clerk 6.0 is a complete font management utility. It provides the
capabilities to view an entire character set, find key sequences for
those special characters, collect font specs for a given point size,
obtain general information about your system and it's configuration, and
generate reports and font lists for easy reference.
Font Clerk 6.0 can be extended through the use of a drop folder called
"FC Scripts". AppleScripts dropped in to Font Clerk's "FC Scripts"
folder, appear in it's "Scripts" menu, allowing the user to expand the
capabilities of Font Clerk. As Apple extends AppleScript, new
capabilities can easily be added through the use of these scripts.
System requirements: Font Clerk 6.0 will run on any Macintosh running
System 7.0 or later (System 7.5 recommended). It supports both color and
black & white monitors.
[Archived as /info-mac/font/util/font-clerk-602.hqx; 387K]
Date: Mon, 7 Oct 1996 03:29:56 -0700
Subject: [*] Font Gander 1.0.3
=46ont Gander is small, simple application which lets you view fonts
without having to install them. Also prints beautiful specimen sheets.
Works with Adobe Type Manager=99 3.0 and above to allow high-rez imaging
of Type-1 fonts. Best used as a "drag-and-drop" application.
v1.0.3 fixes a potential problem when closing non-installed font files.
Also saves a few kilobytes by using a smaller windoid WDEF and
defaulting to System 7.5's built-in windoid WDEF when that's available
(this should also improve it's Copland-compatibility).
* System 7.0 or higher.
* Works best with Macintosh Drag and Drop installed (standard in System
7.5).
Hugh Johnson
[email protected]
I give permission for my program to be included on the Info-Mac CD-ROM.
[Archived as /info-mac/font/util/font-gander-103.hqx; 94K]
Date: Mon, 7 Oct 1996 20:32:23 -0700
Subject: [*] TidBITS#348/07-Oct-96
If you've heard future versions of the Mac OS won't be backward compatible
with today's software, think again: it wouldn't be the first time
mainstream media got something wrong about Apple. Also in this issue, news
on updates to UserLand Frontier and Corel WordPerfect, Adam explains some
of the reasons we've put DealBITS on hiatus, Matt Neuburg concludes his
review of QuicKeys 3.5, and we welcome Aladdin Systems on board as a
TidBITS sponsor.
Topics:
MailBITS/07-Oct-96
The Deal with DealBITS
Getting It Backwards
Form, Function, and QuicKeys 3.5, Part 2
[Archived as /info-mac/per/tb/tidbits-348.etx; 29K]
Date: Mon, 07 Oct 1996 14:29:21 -0400
Subject: (Q) WGS 7250 and 1710AV ??
Any reason my WGS 7250 will not work with my AppleVision 1710AV
display?
Mike, [email protected]
#include /* Sanad Support Technologies */
Date: Mon, 7 Oct 1996 12:18:47 -0700 (PDT)
Subject: 603e vs 604
I'm going to be buying a Power Computing Mac sometime in the near future.
Is paying for the 604 chip worth it or should I just buy the 603e machine.
I was thinking 603e at 200+ MHZ. I'm just going to use it for home stuff,
school, financial calculations and games.
Please reply via email.
Jack
Date: Tue, 8 Oct 96 11:47:09 +0200
Subject: [Q] Straight-through serial cable
I need a "straight-through" Mac 8-pin mini-DIN to 8-pin mini-DIN serial
cable.
It looks like an ordinary ImageWriter/StyleWriter serial cable but it's
wired differently: pin 1 to pin 1, pin 2 to pin 2, ... , pin 8 to pin 8.
Apparently the normal Apple cable's wiring crosses over at some point,
which is not what I need.
Does anyone know where I could find such a cable? I need an email address
or fax number, or a voice number if nothing else is available. I can't
call 800 numbers (I'm not in North America). TIA.
-- Phil Hudson -- [email protected] -- http://www.wp.com/hudson23/ --
Date: Mon, 7 Oct 1996 14:15:56 -0500
Subject: Empty font suitcases
Hello all.
This is chapter two in my continuing saga of adjusting to using 7.5.3 on
a Performa 6320 (instead of 7.0.1 on a LCII). Several members of my
family observed that some fonts (displayed properly previewed in the
ClarisWorks font menu) really just drew the system default font.
Research indicated that numerous font suitcases (obviously installed by
me since they were dated after my purchase of the system) were present,
but when opened, there were no entries. The question is, where did these
come from? I've changed the distribution CD (nope) and I've reinstalled
my printer driver (Stylewriter 2500) (nope). Two of the fonts in
question are called 'cocoa' and 'dear teacher'. Anyone have any ideas?
John Withers
Date: Mon, 07 Oct 1996 09:43:19 -0400
Subject: Ethernet time synchronisation
Hi!
I am looking for a shareware (or solution) that would help me
synchronize all my macs on my ETHERNET network so that all the users
will have exactly the same time.
M. Theriault, Montreal, Quebec
[email protected]
Date: Mon, 7 Oct 1996 11:27:26 -0700
Subject: FontBox 2.0 Problems
I downloaded FontBox 2.0 from the InfoMac archives, and let the program
take a look at my Fonts folder, which contains under 100 fonts, not
counting multiple bitmap sizes.
I got a number of diagnostic messages that were simply wrong:
(1) Several bitmapped fonts were claimed to be present in duplicate:
None of them were.
(2) Several bitmapped fonts were claimed to be without Postscript fonts:
In most cases, the Postscript fonts were present.
(3) Several PostScript fonts were claimed to be without Bitmapped fonts:
In all cases, the bitmapped fonts were present.
(4) The list "Bitmapped fonts without PostScript fonts"
contained one Truetype font. Why is it supposed to have a PS font
attached?
None of this mis-diagnosis could be attributed to corrupted fonts:
There were none.
Needless to say, I will not entrust my Fonts folder to a program giving
this kind of diagnosis, whether it won a MacUser Shareware award or
not.
In case it matters, my Mac is a Mac II fx, running System 7.1.
Herb K
Date: Mon, 7 Oct 1996 18:24:50 +0200
From: [email protected] (Anneke M.Th. Harbers and Ard Jonker)
Subject: Help with MAC LC
>2, Can we hook the 2 machines up, so both can use the same data. They sit
>back to back on desks. They do have a Syquest 135EZ which I believe they
>can hook up to either computer.
>Since this is a non-profit organization and money is in short supply, we
>need to do this as cheaply as possible.
You might want to contact Kevin Raner ([email protected]), to see if you
can get a suitable version of his mac-to-pc-and-vice-versa 'communication
software' StarGate. It runs through an RS232 cable (back to back, the cable
could be as short as 30 cm!). StarGate is said to make files sharable
between Mac and PC. Ask Kevin for details; I don't have a PC, so I can't
tell you.
ard
Date: Mon, 7 Oct 1996 22:10:30 -0500
Subject: How to Downgrade to 7.5.3
Ken wrote:
> System 7.5.5 has been crashing on me way too often to be of any benefit.
> I haven't noticed any reliability or speed improvements either.
> So I'm now trying to remove it and re-install System 7.5.3. Is this
> possible?
> Those upgrade disks for 7.5.3 and 7.5 have "remove" buttons, but they
> become unselectable because I am running 7.5.5. How can I get around
> this?
> What is the easiest way to downgrade back to an earlier version of
> System?
This is not "blessed" by Apple, but what I have done successfully is simply
replace (Finder,System)-files of 7.5.5 by (Finder,System,System 7.5
Update)-files of 7.5.3.
I created two new empty folders and hid the active System-file in one and
the active Finder-file in the other. I dragged the two folders to the
trash. You can't delete them yet; they are still in use.
>From the backup copy I had made of the System Folder containing 7.5.3 I
copied 7.5.3's three-file "package" into the current System Folder.
Finally I rebooted with 7.5.3 and emptied the trash.
As I said, the above procedure, as far as I know, is NOT blessed by Apple.
Your mileage may vary. You may lose everything although I never have.
As a last reminder, some System settings may have to be reset when a
System-file is replaced. Settings such as are made through the Color and
Desktop Patterns control panels, and settings such as are made through
Chooser.
Hope this helps.
Pete Roberts
MacPartners Development [email protected]
(617)332-5082 (Voice) (617)965-7425 (Fax)
Date: Mon, 07 Oct 1996 10:26:33 -0400
Subject: Info-Mac Digest V14 #227
[A] HD Optimizers
On: Fri, 27 Sep, JonYo wrote
>Does anyone know of a good program, shareware or not (but shareware would
>be good!), to defragment one's hard drive? I have a PowerMac 7500/100 with
>a 1 gigabyte drive, and with about 9 months of ownership in which time
>countless netscape cache files have come and gone, as well as countless
>graphic and sound files, I'm thinking that my HD needs a little help. The
>last time I even SAW a program to do this was on my friend's old 386
>running DOS at least 6 years ago. Does something like this exist for the
>Mac? I've looked a lot, and I haven't seen anything. Thanks...
A warning about Norton Utilities. I have a PowerMac 7500/100 and used to
run Norton Utilities. However, I had a problem with it where it would destroy
my catalog file. I had to reformat my disk and reinstall my software (I was
lucky enough to have it backed up). I think this problem is particular to
PCI Macs. If you look at the fine print on the MacTools box, you'll also see
that it is owned by Symantec. I suspect that it may have the same problem.
Can anyone confirm this?
Date: 8 Oct 1996 11:04:25 -0500
Subject: Mac to DOS
Thanks for your help in the past. Could you post the following for me.
Is it possible to convert Mac Microsoft Word files to DOS Microsoft files on
my Mac so that they may be sent from my Macintosh to a DOS (Windows) machine
(with Microsoft Word) as an email enclosure. That way the recepient (who is
much more of a computer novice than I am) can open them directly. Please
reply to me at
[email protected]
-Steve
Date: Mon, 7 Oct 1996 21:04:29 -0800
Subject: Quicktime Musical Instruments Program/Patch Changing?
Hi. I'm trying to use Quicktime musical instruments with Opcode's MAX.
With OMS 2.2, I have no problem using Quicktime Musical Instruments in
place of a normal MIDI sound module, but all I can seem to get is a piano
sound, which I'm assuming is program 1. It seems to ignore the program
change messages I send to it. I've been trying to search through the stuff
at Apple's quicktime site, and I can't even find anything that is
specifically about QTMI. Anybody know about this problem or where I can
find info on QTMI? Thanks in advance...
- JonYo ([email protected])
Date: Mon, 7 Oct 1996 18:24:54 +0200
Subject: RAM-pig
>On October 2, Dale Keiger wrote:
>> I have OS 7.5.5 on my PowerMac 7100/66. Last week, it was consuming 11.4
>> megs of RAM, out of my total of 16 megs.
>> Tired of freeze-ups from depleted memory, I doubled the RAM a few days ago,
>> from 16 to 32 megs. On booting my newly souped-up machine, I found that now
>> the OS is consuming 17+ megs! The only change I made to the machine was
>> the additional RAM; all other settings (INITs, C-DEVs, etc.) remained
>> unchanged. Why is my system such a RAM-pig? Can I do anything about it?
Try NetWeight; a small extension that gives you a graphical (and text)
overview of how your memory is being occupied by extensions and control
panels.
ard
Date: Mon, 7 Oct 1996 09:57:44 -0700 (PDT)
Subject: Seeking Word-counting Program
I'm looking for a program that counts how many times each word appears
in a document and lists them, like this:
The 5
an 3
with 3
or 2
If you have seen anything like this or can suggest where to find it,
please let me know. (A similar program, MacTravesty, won't list whole
words)
Date: Mon, 7 Oct 1996 17:40:17 -0700
Subject: Senior Math Educational Software
I am looking for any programs/CD-ROMs which take an interactive
approach to tutoring senior maths (specifically British Columbia, Canada,
Math 12--but any localized program for Canada/US will do). Most of the
catalogues and people I have talked to only know of junior programs.
Please e-mail me a copy of any suggestions for titles that you might
have.
Mr. Blayne Welk || [email protected]
Date: Mon, 7 Oct 1996 16:07:15 -0400 (EDT)
Subject: starting up from zip disk?
i'm sure this has been asked before, but how do i start up from a zip disk (it
has all the right system folder stuff)? i've tried setting it to be the
startup disk, and i've also tried holding down command-option-shift-delete on
startup to "bypass" the hard disk, but no matter what, i boot off the internal
hard drive. i suppose i could temporarily trash the system folder on my hard
drive, but for what should be obvious reasons, i am hesitant to do so. any
advice?
-+- David P. Baker * [email protected] * http://www.wjh.harvard.edu/~dpb/ -+-
--Info-Mac-Digest--
