DeskPix 1.1
DeskPix 1.1
Download: http://archive.info-mac.org/cfg/deskpix-151.hqx
DeskPix 1.1 is a desktop picture randomizer for MacOS 8.5. Tell DeskPix
which pictures you want it to choose from, by one of several different
selection methods, and it will randomly set a new desktop picture each time
you restart your computer.
The major change between Version 1.0 and 1.1 is to update DeskPix to be
compatible with MacOS 8.5.
DeskPix 1.1 requires a PowerPC-based Mac running MacOS 8.5. It will not work
with MacOS 8.1 or earlier. MacOS 8.5 requires at least 16 MB RAM.
If you use MacOS 8.0 or 8.1, you can use DeskPix 1.0, which supports your
system-version. Version 1.0 is available at the SearchWare Solutions
web-site.
