Delete ObjectSupportLib
Download: http://archive.info-mac.org/cfg/delete- ... rt-lib.hqx
Mac OS 8.0 and higher has the ObjectSupportLib function built in. So the
ObjectSupportLib file should be removed from your Extensions folder.
Unfortunately, some installers automatically create an ObjectSupportLib
file in your Extensions folder. This short AppleScript -- in text so that
you can change the code, if you wish -- removes the unwanted file and
places it in the trash.
Buck Donham
Hilo, Hawaii
