ClockSync II 1.4.0
ClockSync II 1.4.0
Download: http://archive.info-mac.org/cfg/clock-sync-ii-140.hqx
ClockSync II 1.4.0 is available!
Author's email address: [email protected]
If you have two or more Macintoshes, you probably notice that the clocks
drift apart as time goes by. This can range from being a minor nuisance to
a problem, especially if you do a lot of synchronizing between the
Macintoshes. ClockSync II synchronizes the clocks between two or more
Macintoshes, by setting the clocks of the "Servant"Macintoshes to that of a
"Master" Macintosh.
ClockSync has two components. The ClockSync Master runs continuously on
the "Master" Macintosh, while the ClockSync Servant can be run on any other
Macintosh on the network to update its time.
All of my utilities can be registered through the Kagi shareware system.
Version 1.4.0 has the following enhancements:
- Master: Added log window.
- Master: Added network timeout setting.
- Master: Added ability to hide main window for a faceless application.
Shareware; $5 for a 3-user license with larger licenses available.
