ClickPad II 2.2.5
ClickPad II 2.2.5
Post by Info-Mac » August 14th, 1998, 9:00 am
Download: http://archive.info-mac.org/cfg/click-pad-225.hqx
This is ClickPad II version 2.2.5, Copyright (c) 1996-1998 Dan Wright.
ClickPad II is shareware (US$14) - see enclosed "Read Me" for details.
ClickPad II requires a PowerBook with a TrackPad; specifically, the
PowerBook 520, 540, and 5300 families are supported. You can just tap the
TrackPad to click the mouse button, double-tap to double-click, or tap-drag
to lock the button down for dragging.
