Download: http://archive.info-mac.org/cfg/cd-sunrise-22c.hqx
CD-Sunrise is CD-ROM driver for ANY SCSI CD-ROM drive. CD-Sunrise allows your
Mac to use ANY CD-ROM drives. To install CD-Sunrise just drag and drop on
System Folder and restart your Mac. CD-Sunrise searches SCSI device ID
from 6 to 1. If you are going to use with other CD-ROM device, CD-Sunrise
will be loaded for biggest SCSI ID drive.
CD-Sunrise works any Macintosh. I've never heard any problem regarding some
mismatch with Mac/OS. But there is possibility that CD-Sunrise doesn't work
with some knid of CD-ROM drives; for example, juke-box type, don't support
basic SCSI command to work only with their driver, etc.
CD-Sunrise is very famous in Japan. Almost 10,000 people downloaded this
driver.
I tested following CD-ROM drives using CD-Sunrise. It worked fine.
maker model vendor
1. | HP (Hewlet Packerd) | TXM3301A1 | TOSHIBA
2. | Sun Microsystems | MODEL 411 | SONY
3. | Silicon Graphics | TXM3301E1 | TOSHIBA
4. | Apple Computer | CD-300(i ) | SONY
5. | Sony | CDU-7811-10 | SONY
6. | Caravelle | CD-100M | TOSHIBA
CD-Sunrise is freeware. You can copy, distribute, post other site.
If you have any question please send e-mail to [email protected]
*) CD-Sunrise doesn't support music CD and ISO format.
Thank you,
Junji Kanemaru
