AppWatcher
AppWatcher
Download: http://archive.info-mac.org/cfg/appwatcher-21.hqx
AppWatcher is a shareware application that watches and records which
applications are being used, and for how long.
Why use AppWatcher?
* You're a business owner, and you want to see how your employees are using
their time on the computer. AppWatcher tells you how much time they've
spend using MS Word as well as how much time they've spent using the game
"Splatter".
* You're a parent, and you want to see how your kids are using their time
on the computer. AppWatcher tells you how much time they've spend doing
their homework as well as how much time they've spent using the game
"Splatter".
* You're a manager, and you want to upgrade your software. What products
do you upgrade? AppWatcher tells you which programs are used most often,
which helps you decide which software to upgrade.
* You're a consultant, and you charge your client for every hour you spend
using PageMaker and MS Word. AppWatcher tells you how much time you've
spent using these programs, allowing you to accurately bill your client.
* You're a Mac user, and you're simply just curious how your Mac is used!
The latest AppWatcher is always available at
