AppSizer 2.31
AppSizer 2.31
Download: http://archive.info-mac.org/cfg/appsizer-231.hqx
AppSizer is a control panel that allows you to modify an
application's MultiFinder partition size as you launch it. To do
this, you simply hold down the control key as you launch the
application and AppSizer brings up a dialog that lets you specify
the application's partition size.
Version 2.3 adds the ability to save new memory partition sizes for
applications on read-only media such as CD-ROM and locked network
volumes. This is done via a the preference file.
Version 2.31 updates the registration information.
Michael Peirce [email protected]
Peirce Software http://www.peircesw.com/
Makers of Smoothie, AppSizer, DeskPicture, & ShareDraw
