Talking Dictionary Patches
Download: http://archive.info-mac.org/cfg/ahtd-40 ... atches.hqx
These are some hacks for the American Heritage Talking Dictionary 4.0
program, PPC & 68K versions. (There are a few patches that will only work
on 68K versions and are so marked.)
Included are patches for PPC and 68K versions that will remove the
irritating "No Multimedia" warning dialog put up by the program at startup
whenever the original CD is not mounted. The few others will change some
font and size preferences in various windows.
This is freeware, and is not endorsed by Softkey or The Learning Company,
although I heard they were giving out the 68K dialog patch to people who
complained about the problem.
joe peret.
