Troubleshooting Using the Internet
Knight
Post by Knight »
Alan Zisman shares an important troubleshooting tip: Computers are complicated systems, and all are prone to problems. Most can be fixed, however, and most of the time someone has had the same problem as you and posted the solution online. Often, as in this case, the solution may be quick and easy, but non-intuitive. Before giving up, check online. Remember, Google is your friend.
Full Low End Mac Article
