Download: http://archive.info-mac.org/cmp/pkzip-203.hqx
PKZIP Mac is an advanced data compression program for Macintosh
systems running System 7 or higher. PKZIP Mac is compatible
across many computer platforms, allowing you to transfer zipped files
from one computer to another.
While powerful, PKZIP Mac is easy to use. You can customize PKZIP Mac's
settings with a variety of options. For example: use a faster
compression method for speedier operations, use a higher compression
ratio to save the most disk space, or use passwords to prevent
unauthorized access to your most sensitive files.
PKZIP Mac is a program for compressing data files. Compressed files take
up less disk space. Compressed files are stored in a single Zip Archive.
You could think of a Zip Archive file as an envelope for files. When a
file is compressed, a copy of the file is placed into the Zip Archive.
Putting files in a Zip Archive makes your file lists less confusing.
Many files can be included in one Zip Archive.
