MacRAR 2.0.1, the RAR compressor for the Mac
Download: http://archive.info-mac.org/cmp/macrar-201.hqx
MacRAR is a RAR archiver for the Macintosh (RAR is a common compression
format coming from PC with attractive compression rates and options). It
allows to extract RAR archives or compress files (including Mac files using
MacBinary III).
MacRAR uses a modern Mac interface (Appearance Manager, Navigation
Services, AppleScript, Drag'n Drop,...) but remains compatible with old Mac
(newer than Mac SE) or System (greater than 7.0).
The RAR implementation (i.e. MacRAR) is a freeware, however it uses RAR
compression RAR which is a shareware. Then you should register MacRAR to
http://www.rarsoft.com (it uses the same registration codes as WinRAR) in
order to get all RAR options.
A French version is also available at MacRAR home page
http://www.capway.com/dufay
This program can be be included on the commercially available CD-ROM of the
archives and would fit very well in info-mac/_Compress_&_Translate/
Guillaume Dufay
