util - MacBinary II+ v1.0.1
Download: http://archive.info-mac.org/cmp/mac-bin ... us-101.hqx
_______________________________________________________________________
Peter N Lewis Ph: +61 9 368 2055
MacBinary II+ is a System 7 drag&drop converter for MacBinary files. It
has no User Interface, simply drop a MacBinary file on it and it will be
decoded, drop any other file or folder on it and it will be encoded.
MacBinary II+ should be fully compatible with all current MacBinary
encoders/decoders, and extends the format to include folder hierarchies
(although no other decoder will be able to decode folder hierarchy
MacBinary files created by MacBinary II+).
Version 1.0.1 corrects a problem that stopped MacBinary II+ from
recognizing MacBinary I files. I don't normally like posting such
a minor change, but since I don't have any grand plans for the program
anyway, and since the problem is fairly noticable, I decided to post
this fixed version.
MacBinary II+ should work on any System 7 Mac. If it doesn't, let me know.
MacBinary II+ is free for any use.
Hope its useful to someone,
Peter.
MacBinary II+ v1.0.1 Copyright 1992-93 Peter N Lewis
