[*] CRLF v.1.2.0
[*] CRLF v.1.2.0
Download: http://archive.info-mac.org/cmp/crlf-120.hqx
Attached please find the sit-hqx archive of CRLF
version 1.2.0. This version added the following features:
1) Balloon help
2) A bug fix for CR->CR conversion.
Hope it will be useful.
Best wishes,
Natsu Sakimura
CRLF -- a CRLFCRLF file converter
FILE: CRLF
ver.: 1.2
Type: Application
Author: Natsu Sakimura
System Requirement: System 7.0 or later
Distribution: DONATEWARE(Freeware) (see Asking your favour:
section below for terms and conditions)
Description:
CRLF is a drag & drop application which performs
the conversion of CR(Mac), LF(Unix) and CRLF(PC) files. It
auto-detects the end of line code of the file which was
dropped and converts to the desired file type. Once you
have set up the preference, you will rarely need to make
any interaction with CRLF later.
CRLF converts the file "in place". The filename stays the
same before and after the conversion. You will notice that
it was converted just by looking at the icons. You can
set up these icons by specifying the creator for each type
of output file.
Also, CRLF is capable of dealing with Japanese text, unlike
some other similar utilities.
New Features:
Fixed the bug that did not process the file properly if
the input and output EOL characters were the same.
Thus, you can now use it to just change the creator.
