backup_by_stuffit_223e/AppleScript
Download: http://archive.info-mac.org/cmp/backup- ... t-223e.hqx
backup_by_stuffit_223e/AppleScript (Freeware),only for users of MacOS8.0
or later.
* This is an AppleScript script that will make a stuffed backup file by
StuffIt LIte 3.5 or later and automatically replace its content with
modified files.
* If you make a backup file into a floppy disk,the disk will be soon
full with files. But if backup files are stuffed,you can save backup
files almost twice as many.
* Once you choose which folder to backup into which disk,and let this
make a stuffed backup file in the disk, only by double-clicking,this
will choose files which in the original folder are modified after the
modification date of the backup file ,and replace these files in the
backup file.
* THIS VERSION COPES WITH THE CHANGE OF APPLESCRIPT WITH MACOS8.
$B!!(B USER OF MACOS7.6.1 OR BEFORE HAD BETTER USE 2.1.2.VERSION WHICH IS
FASTER.
* Ver2.2.3 removed another bug of causing error when folder contains
only one file.
* System requirement: MacOS8.0 or later,AppleScript1.1.2
* You need a registered version of StuffIt Lite 3.5 or later.
