Acme Filters_236
Acme Filters_236
Post by Info-Mac » August 20th, 1997, 9:00 am
Download: http://archive.info-mac.org/cmp/acme-filters-236.hqx
Acme Filters 2.3.6 (C)1997 by Eric V. Curtis All rights reserved
Acme Filters takes the place of many separate freeware/shareware
utilities you may be currently using. It started out as a simple
file converter to translate some old Smith-Corona word processor
files into text files I could use on my Macintosh. Then I realized
my code would make a good shell for any type of drag-and-drop filter.
So, I combined several filters I occasionally use into one "all-purpose"
drag-and-drop application. Full source code is also included so you
can add your own filters or modify the included filters.
Eric Curtis
