Info-Mac Digest V16 #190
Subject: Info-Mac Digest V16 #190
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Tue, 20 Oct 98 Volume 16 : Issue 190
[*] 3D-Box
[*] AppSwitcherControl1.1
[*] AutoShare 3.0, a freeware list server
[*] backup_by_stuffit_222e/AppleScript
[*] Blobs 2.0
[*] Bookmark Thing 1.0b10.
[*] cheaphtml-10-jp.hqx
[*] cheaphtml-10.hqx
[*] Color Picker Pro 2.5.0
[*] DockZone 1.0.7 update
[*] Duplicate Type/Creator Database v1.0
[*] EasySwitcher
[*] Falcon NC 2.0 RPN/Algeabraic calculator
[*] FinderPop1.7.2F - Rehausse les menus contextuels sous MacOS8
[*] Function Generator 2.3(PPC)
[*] Gantt Chart for FMPro
[*] GrooveMaker1.1
[*] Mac CallerID 1.2.1
[*] MacTypingTutor
[*] OneApp CineSlider 4.0 Italian Version - Movies, sounds and
[*] Palms Kaleidoscope scheme
[*] Pharaoh Kaleioscope scheme
[*] PictureSnooper98
[*] Power Windows 2.0.4
[*] ShockBox Version 1.0.2
[*] Smile 1.5.2, a free AppleScript editor
[*] tetratrap-10.hqx
[*] TidBITS#451/19-Oct-98
[*] Un-SourceSafe Abstract
[*] YellowView 2.1.1
[*] YP Refraction (french version)
containing gigabytes of freely distributable Macintosh software.
Email Addresses and Instructions:
the Subject line.
the Subject line.
form at before contacting us.
FTP and Web Addresses and Instructions:
* To submit files larger than 800K, email a description to
binhexed file to info-mac.org, using the userid "macgifts and the
* A full list of Info-Mac mirror sites is available at the URL below:
* Search the archive at .
Info-Mac volunteers include Gordon Watts, Adam C. Engst, Demitri Muna,
Michael Bean, Liam Breck, Hugh Lewis, Tom Coradeschi, and Shawn Bunn.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #190"
Date: Mon, 19 Oct 1998 22:49:06 -0700
Subject: [*] 3D-Box
3D-Box
* Requirements:
PPC, 6 MB RAM,
MacOS 7.55 and up, (8.0 and before also need the Appearance manager; info
at the website)
* Description:
3DBox is an application that creates boxes in OBJ format and matching
texture map templates as PICTs. You give the heigth, width and length of
the box and decide in which resolution you would like to get the texture
map.
The created models can be used in any 3D program that supports OBJ import
and parametric mapping of textures.
3DBox provides the option to leave gaps at certain edges in the texture
map, so you can create completely different designs for the different sides
of your box without getting the usual inaccuracies at the edges of the box.
* Further notices:
3D-Box may be included in commercially available CD-ROM of the archives.
[Archived as /info-mac/dev/3d-box.hqx; 225K]
Date: Mon, 19 Oct 1998 22:48:46 -0700
Subject: [*] AppSwitcherControl1.1
Description:
AppSwitcher Control is a handy application which allows you to customize
the appearance and behavior of the Application Switcher in Mac OS 8.5.
AppSwitcher Control is free.
Requirements:
AppSwitcher Control requires a PowerPC Macintosh running Mac OS 8.5.
Version History:
v1.0 1998-09-17
- Initial Release. My first Macintosh application ever.
v1.1 1998-09-21
- Revised layout of options using more visual elements. Eliminated popup menus.
- Added miniature representation of the screen which allows you to visually
set position, orientation, and grow direction, all at once.
- Added ability to edit name width. Click the arrows to increment or
decrement by 10 pixels. Shift-click to increment or decrement by 1 pixel.
- Added ability to order by name or launch order, normal or reverse.
- AppSwitcher Control now reads the Application Switcher's settings only
the first time you launch it. When you quit AppSwitcher Control, it saves
your settings to its own preferences file. From then on, it reads settings
from its preferences file at launch. This results in much faster launch
times.
- AppSwitcher Control now does a better job of loading the existing settings.
- AppSwitcher Control now remembers which tab was frontmost when you last
used the application.
- Added balloon help for just about everything.
- General cleanup of the internal workings of the app.
Questions?
mailto:[email protected]
http://www.pascal.com/software/
[Archived as /info-mac/gui/app-switcher-control.hqx; 382K]
Date: Mon, 19 Oct 1998 22:49:18 -0700
Subject: [*] AutoShare 3.0, a freeware list server
AutoShare is a robust and speedy list server and auto-responder for the
Macintosh. Available for both 68K and Power Macs, requiring little memory
and tested with Mac OS 8.1, AutoShare can handle hundreds of mailing lists
and thousands of subscribers for each list. Full scriptability is
supported, and an Admin application with balloon help makes it easy to
configure the richly featured server application.
The AutoShare archive comes complete with script samples and documentation
covering features such as multiple preference sets, standard and database
subscriber formats, fully automated web archives, remote administration by
email, multiple language support for subscribers, subscriber and
administrator web forms and advanced mail-back confirmations. AutoShare is
the only Macintosh list server offering a built-in automated bounce and
unsubscribe module, supporting both hard and soft bounces. It can be used
to launch external applications and includes built-in Cron support. Process
extenders, often small AppleScript applications, allow the administrator to
extend the AutoShare server's normal processing.
Version 3.0 introduces two database formats for subscribers as its major
feature and furthermore offers support for list-specific languages for
subscribers, MIME digests as attachments, additional commands for remote
administration by e-mail and support for more bounce formats plus minor
improvements and bug fixes. The AutoShare web site at
offers information on releases and
discussion lists.
Mikael Hansen
[Archived as /info-mac/comm/inet/mail/autoshare-30.hqx; 1879K]
Date: Mon, 19 Oct 1998 22:49:20 -0700
Subject: [*] backup_by_stuffit_222e/AppleScript
backup_by_stuffit_221e/AppleScript (Freeware),only for users of MacOS8.0
or later.
* This is an AppleScript script that will make a stuffed backup file by
StuffIt LIte 3.5 or later and automatically replace its content with
modified files.
* If you make a backup file into a floppy disk,the disk will be soon
full with files. But if backup files are stuffed,you can save backup
files almost twice as many.
* Once you choose which folder to backup into which disk,and let this
make a stuffed backup file in the disk, only by double-clicking,this
will choose files which in the original folder are modified after the
modification date of the backup file ,and replace these files in the
backup file.
* THIS VERSION COPES WITH THE CHANGE OF APPLESCRIPT WITH MACOS8.
$B!!(B USER OF MACOS7.6.1 OR BEFORE HAD BETTER USE 2.1.2.VERSION WHICH IS
FASTER.
* Ver2.2.2 removed the bug of causing error when folder contains only
one file.
* System requirement: MacOS8.0 or later,AppleScript1.1.2
* You need a registered version of StuffIt Lite 3.5 or later
Tomokazu Hanafusa
http://www.117.ne.jp/~t-hnfs
[Archived as /info-mac/cmp/backup-by-stuffit-222e.hqx; 78K]
Date: Mon, 19 Oct 1998 22:49:03 -0700
Subject: [*] Blobs 2.0
A fun and really addictive strategy game the features 3D rendered
graphics, lots of animation and sound effects!
by Lars Gafvert
Foxchange Shareware
www.foxchange.com
[Archived as /info-mac/game/blobs-200.hqx; 871K]
Date: Mon, 19 Oct 1998 22:49:16 -0700
Subject: [*] Bookmark Thing 1.0b10.
Bookmark Thing is a light-weight bookmark assistant, intended to work in
conjunction
with Internet Config and your favourite internet applications.
It was designed with these two principles in mind:
1. I don't want yet another application for managing hierarchical
collections
of things - I've already got something called the Finder, which works
quite
nicely thank you very much.
2. I don't want all my bookmarks linked to any particular application -
today
I'm using IE4 and Anarchie; a while ago, it was Netscape and Fetch;
tomorrow, who knows...
More details can be found at:
Sam Deane
Elegant Chaos
5th October,1998
[Archived as /info-mac/comm/inet/web/bookmark-thing.hqx; 600K]
Date: Mon, 19 Oct 1998 22:48:38 -0700
Subject: [*] cheaphtml-10-jp.hqx
Here is my software entitled "CheapHTML(J)".
This application is Japanese version.
This makes a simple text with HTML4.0 settings.
This is FAT application.
The package contains no virus.
The abstract is below.
Thank you.
10/5/98
Junzo Sato
email:[email protected]
Abstract:
CheapHTML(J) makes a simple text with HTML4.0 settings.
The parameters: doctype, title, charset, lang, and email are available.
[Archived as /info-mac/text/html/cheaphtml-10-jp.hqx; 548K]
Date: Mon, 19 Oct 1998 22:48:39 -0700
Subject: [*] cheaphtml-10.hqx
Here is my software entitled "CheapHTML".
Thank you.
10/5/98
Junzo Sato
Abstract:
CheapHTML makes a simple text with HTML4.0 settings.
[Archived as /info-mac/text/html/cheaphtml-10.hqx; 547K]
Date: Mon, 19 Oct 1998 22:48:40 -0700
Subject: [*] Color Picker Pro 2.5.0
Color Picker Pro is a small drag and drop savvy application that aids in
finding color hex values for use with HTML production. Color Picker Pro is
more than just a RGB to hex converter however! It can literally pull
colors out of windows, icons and Desktop backgrounds. If you can't find a
color that you're interested in using the former method, you can just as
easily utilize any of your System-level color pickers a la the Color Picker
Pro application. Once you've found the color you want, you're only a
click, menu choice or key combination away from pasting your hex value into
any text-based HTML editor. Color Picker Pro will also allow you to store
frequently used colors, undo and redo color changes as well as finding the
nearest Netscape 216 Palette color.
System requirements:
* System 7.5
* Power Macintosh
* Drag and Drop Functionality
* 16 or 32 bit color preferred
For more information, please read the Read Me file enclosed, or visit our
Web page:
http://www.rootworks.com/cpp
Mike McNamara
Rootworks
[Archived as /info-mac/text/html/color-pickerpro-250.hqx; 753K]
Date: Mon, 19 Oct 1998 22:48:47 -0700
Subject: [*] DockZone 1.0.7 update
Objective Software announces the maintenance release of DockZone 1.0.7.
* Version 1.0.7 (98/10/10)
- fixed a bug with allegro (MacOS 8.5)
DockZone delimits an area on the right side of your main screen, where the
volumes and the trash are usually located, giving your Desktop a BeOS or
Rhapsody look. The control panel lets you customize the dock colors and its
width.
Support: mailto:[email protected]
Author: Harry Alloul
Price: $10 (shareware, see docs for more info)
Register: http://order.kagi.com/?HL&S
Info: http://www.objectivesw.com
Have Fun!
[Archived as /info-mac/gui/dock-zone-107.hqx; 94K]
Date: Mon, 19 Oct 1998 22:48:45 -0700
Subject: [*] Duplicate Type/Creator Database v1.0
>From the creator of the Type/Creator Database here is:
Duplicate Type/Creator Database v1.0, October 6, 1998
A total of 461 code pairs.
A collection of problematic Type/Creator pairs -
same codes assigned to 2 different applications.
These applications and INITs may clash and cause
problems if both are active at the same time.
Data Base interface program by Daniel Azuma
Data Base maintained by Ilan Szekely.
Files included are:
Duplicate Type/Creator DB v1.0
Duplicate Type/Creator ReadMe (this file)
For more details / explanations, take alook at URL:
OR
Address for snail-mail and shareware fee:
Ilan Szekely
P.O.B 3942
Jerusalem 91039
ISRAEL
E-mail - [email protected]
[Archived as /info-mac/info/sft/duplicates-tcdb.hqx; 111K]
Date: Mon, 19 Oct 1998 22:48:49 -0700
Subject: [*] EasySwitcher
Subject: EasySwitcherV1.0 Switch Between/Hide Applications With Hot Keys
EasySwitcher 1.0
If you are tired of always moving the mouse to the upper right of the screen
to change between open files, or to hide open applications, EasySwitcher can
help. EasySwitcher allows for Macintosh users to have the one good feature
of Windows users (plus a few things you can't do on a Windows machine). By
pressing Control-Tab you will get a Dialog that shows all your applications
that are running (Icons). You can toggle through your applications to bring
that application to the front.
Easy Switcher doesn't stop there!
* EasySwitcher is NOT an Extension. Thus, it can be started and stopped
like an
application at anytime (without having to restart your machine).
* EasySwitcher 'Watches' what applications you are using, and keeps them
only a few key
strokes away. So that Switching between 2 applications is quick and
easy.
* EasySwitcher even has a hot key to Hide the front application. This helps
keep your
desktop clean from cluttered windows.
System Requirements:
* System 7.1 or Later.
Michael
QSys Software
http://www.qsyssoft.com
[Archived as /info-mac/gui/easy-switcher.hqx; 431K]
Date: Mon, 19 Oct 1998 22:48:43 -0700
Subject: [*] Falcon NC 2.0 RPN/Algeabraic calculator
FALCON-NC vers 2.0.0 RPN/Algeabraic Scientific calculator.
This is not your ordinary calculator. It's a true RPN and ALGEABRIC
calculator in the same package. You can even switch mode right in the
middle of a problem solving sequence. It has superior formatting of results
( 30=B0 23' 43" ) and even automatic ISO and US delimiter setting. (if you
use a coma in entering a number it use it as the delimiter, the same for
the period )
With this calculator you have on-the-fly base conversion, mixed base
arithmetic, unsigned numbers conversion, and more. The application has
been tested with machines from MacPlus and MAC OS 6.0.2 up to Mac OS 8.1
and the newest PowerBook G3 machines.
The Financial mode has automatic features that simplify the calculation
of the basic financial function of Interest, Present Value, Future Value
and Payments. It even has Canadian Mortgage calculation functions.
It has been updated and tested to work on the latest G3 machine (
PowerBook 233 ). This application works as well with the older Mac like
the Plus and the SE.
The calculator has automatic continuous memory of 2000 registers. There
is also a lot of shortcuts for the various modes of the calculator.
Jacques Th=E9riault
[Archived as /info-mac/sci/calc/fal-connc-20.hqx; 205K]
Date: Mon, 19 Oct 1998 22:48:50 -0700
Subject: [*] FinderPop1.7.2F - Rehausse les menus contextuels sous MacOS8
This is the french version of FinderPop.
If you're looking for the english version and haven't found it here, check
out http://www.geocities.com/SiliconValley/Bay/2573/
=46inderPop est un gratuiciel qui rehausse les menus contextuels du MacOS 8.
Il permet entre autres l'apparition des menus contextuels sans l'aide de la
touche contr=F4le.
De plus, il int=E8gre dans les menus contextuels, l'=E9quivalent du menu
"Applications",l'espace m=E9moire disponible, donne acc=E8s au contenu du
Bureau des dossiers ou des disques, et plusieurs autres fonctions dont vous
pourrez ajuster les param=E8tres =E0 votre go=FBt...
Il permet aussi une navigation par menus hi=E9rarchiques au travers des
dossiers du Finder, soit =E0 partir des zones de dialogue Ouvrir/Enregistrer
ou directement dans le Finder.
Gracieusete de Turlough O'Connor ([email protected])
Version francaise par Fawzi Dormeyer d'ImaGiciel ([email protected])
[Archived as /info-mac/gui/finderpop-172-fr.hqx; 313K]
Date: Mon, 19 Oct 1998 22:48:55 -0700
Subject: [*] Function Generator 2.3(PPC)
Function Generator - can generate five different waveforms which are sine,
square, chop, sawtooth, and arbitrary wave using the internal Sampled Sound
Synthesizer in your Power Macintosh. And the frequency of sine wave can be
sweeped by Function Generator. The output wave is 16 bit stereo sound whose
frequency range is from 10 Hz to 9990 Hz in 10Hz steps and the amplitude of
which
can be ajustable from 0mV to 400mV in 50mV steps. Besides it is possible to
select the sampling frequency from 44.1 kHz, 22.05 kHz, 10.025 kHz. In order to
generate arbitrary wave, you should read text file having waveform data
which you
make using Microsoft Excel etc in advance. The file can be read with Drag
& Drop
onto the Function Generator window.
[Archived as /info-mac/gst/snd/function-generator-2.3-ppc.hqx; 197K]
Date: Mon, 19 Oct 1998 22:49:10 -0700
Subject: [*] Gantt Chart for FMPro
Here is a freeware contribution, a FileMaker Pro solution to the challenge
of charting, as bars graphed over time, a series of events, across a page
beginning at the left side with the earliest beginning time and ending with
the latest ending time of any of the bars. This, (so I have been told) is
called a Gantt chart. This, (so I have also been told, after posting
exasperated questions in this very venue), is something you just can't DO
in Excel. There are charting solutions out there, apparently, that will,
and probably they would willingly snatch up exported data from other
applications, but I didn't feel like shelling out for another program just
for this one capability, and probably a few other folks feel the same way.
The interface is simple: each bar (item) is a record; create a new record,
enter start date, end date (in its current form it does not accept time
entries as opposed to date entries, although since it isn't
password-protected you are welcome to modify the field defs), go to next
entry, and when completed run the Set Overall Duration script (visible in
the Script menu) that will calculate the earliest start date and latest end
date in order to graph the collection as a Gantt chart.
The enclosed file comes equipped with global color fields allowing the user
to set a different color for each entry, selectable via a drop-down menu.
The file is easily scriptable from other FMPro solutions: create new
record assumes an item name is in the clipboard, and if a relationship is
defined on the basis of that item name, you can assign start and end dates
from afar, and end by calling the script that figures minimum start date
and maximum end date and prints or displays the resultant graph.
Using FileMaker import, you can also begin with a spreadsheet or
tab-delimited textfile consisting of item name, start date, end date.
This solution is a CPU exerciser; you can watch it draw each row's bar on a
300MHz G3 (12-15 second screen draw), and on a IIci you find yourself
anticipating the result of each pseudopixel thereof as it is calculated (go
get a cup of coffee).
272K (at least on my HD), requires FileMaker Pro 3.x or higher,
cross-platform insofar as I can tell.
[Archived as /info-mac/data/gantt.hqx; 62K]
Date: Mon, 19 Oct 1998 22:48:58 -0700
Subject: [*] GrooveMaker1.1
GrooveMaker+Dancity is actually a combination of two products: the
GrooveMaker software and the Dancity sample collection.
The GrooveMaker is the first groove generator based on a powerful sample
layering engine with huge pre-grouped loop sample libraries called
"songs." Now it's fast and simple to create instant, hi-quality dance
music. With the GrooveMaker, you can play, mix and randomize your own
grooves on the fly, with instantaneous control over 8 stereo loop tracks,
in real-time! Separate volume and pan controls, solo and mute buttons are
at your disposal giving you an intuitive environment to create stunning
grooves. And you can even add your own samples! Shift the tempos (+/-20%)
just like a DJ in a live situation. With the randomization feature, you'll
discover endless loop combinations to keep your sound fresh. Every
combination you hear can be saved on the fly, or marked inside the program
for instant recall.
A Virtual Synth Arpeggiator is also included to give your performance that
rave impact! With 99 sounds and more than 128 presets, a synth snapshot
feature and "smart-notes!"
With the GrooveSequencer you can assemble your marked grooves in a sequence
list with one click. Now you have a full-length song which you can either
mix to your hard disk (as a complete stereo file) or save as eight
individual stereo tracks for subsequent mixing on your hard disk recording
system. But if you think that's quick and easy, check this out . . .
. . . the fastest way to make not one, but millions, of different songs is
with the V-Mix. Here a VIRTUAL DJ instantly assembles 4 random mixes with a
simple click. That's it! And every time you click again, another random
song set is generated. Get hours and hours of instant remixes and never
hear the same thing twice. When you hear something you particularly like,
save it, or just let it run and groove for you all night long.
The Dancity sample collection includes... 504 studio-quality remixable loop
samples (from 98 to 180 bpm) pre-grouped in 8 songs, that can combine to
produce more than 80 million different grooves using the GrooveMaker=AA
soundware engine. Choose from Techno, House, Progressive, EuroDance,
Jungle, Trash, and more. A huge variety of instrumental loops including
Bass, Bass-Drum, FX, Loop, Line, Pad and Percussion, plus Vocals, with
incredibly rich sounds created from massive state-of-the-art gear. A 99
sound, 3 octave virtual synth with more than 3,000 sound events is also
included for real-time performances. All samples are available as 22 and
44kHz, 16 bit files. Studio ready, and Royalty Free! And more loop
collections are just available!
[Archived as /info-mac/gst/snd/groove-maker-11.hqx; 14234K]
Date: Mon, 19 Oct 1998 22:49:12 -0700
Subject: [*] Mac CallerID 1.2.1
Mac CallerID 1.2.1 captures Caller ID information from your local telephone
company. Once the information is received it can speak the caller=92s name, =
page
you via numeric or alphanumeric pager, open a database(AppleScript) and find
the calling parties record.
=46eatures:
Display single or list of calls (up to 9999)
SubstituteCaller
SoundAssign - attach sounds to specificphone numbers
Speak name of caller
AppleScript
Shrink or Hide application when in the background
Preferences
SoundAssign (assign sound to a particular telephone number)
Pop to the front when receiving a call
PageMe (with Pro version ONLY) (numeric and alphanumeric paging using TA=
P
protocol)
Works in the US, Canada, Sweden, England, Puerto Rico
and many other features
Requirements:
Color Desktop Macintosh running system 7 or greater
Modem supporting CallerID
Subscribe to local telephone company's "Caller ID" service
Shareware $20-30 U.S. depending on version.
See "Registration Information" and "Read Me" files for more information.
[Archived as /info-mac/comm/mac-caller-id-121.hqx; 683K]
Date: Mon, 19 Oct 1998 22:49:04 -0700
Subject: [*] MacTypingTutor
MacTypingTutor 4.5.1 replaces MacTypingTutor 4.5, for Power Macs
Now with window graphics that show well on all Power Macs. Now with
typewriter sounds (turned on or off) that make your keyboard sound like a
real typewriter. Users with older Macs should download MacTypingTutor4.3 or
earlier versions; search with keyword: wroger. Shareware fee is reduced for
the coming holidays.
MacTypingTutor is great for beginning typing students. It uses five
integrated work areas that together teach correct finger placement and
memorization of the keyboard keys. Practice exercises focus on single
letters, letter and number sequences, words, sentences, paragraphs, and
free typing. The program offers a spelling checker, user-defined speed
goals, score sheets, time tracking with rest signals, and many other
helpful features. MacTypingTutor comes in the regular version, a special
keyboard version (Dvorak), a French version, and one-handed versions (left
or right). This download is the regular version.
MacTypingTutor takes advantage of the recent Apple System Software
improvements for Power Macs.
MacTypingTutor let's you hide or show: your typing, screen-keyboard, and
feedback reports. You can adjust difficulty level from very easy to hard
(this is a good feature for children). Program automatically remembers your
work-preferences from session to session.
All five modules in download version of MacTypingTutor work, although there
are features in each module that are limited is use. Download and begin by
testing your current typing speed. And if you choose to, hear what it
sounds like to type on a real typewriter.
Additional key words that will help you locate this file in the future are:
type keyboarding typewriter computer Mac Macintosh tutorial school
educational literacy key letter learning language arts tools typing
accurate one handed.
[email protected] [email protected]
W. Rogers, Practical Press, Box 754151, Parkside Station, Forest Hills, NY
11375 USA
Wm. Rogers
Practical Press
[Archived as /info-mac/edu/mac-typing-tutor-451.hqx; 400K]
Date: Mon, 19 Oct 1998 22:48:54 -0700
Subject: [*] OneApp CineSlider 4.0 Italian Version - Movies, sounds and
Abstract/Descrizione:
OneApp CineSlider is a projector for movies, sounds and images. It's fast
and easy to use.
OneApp CineSlider lets you personalize the projection to adapt it to the
most varied needs. You can create projections that are controlled manually
or automatically. You can personalize the projection environment with
colored backgrounds or patterns, use a soundtrack during projection, and
display the names of the images and movies that are projected.
OneApp CineSlider can handle a wide range of graphic and multimedia
formats: QuickTime Movies, QuickTime VR Movies, AIFF audio files, and all
the main graphic formats such as JPEG, TIFF, Pict, Photoshop, PNG,
MacPaint, GIF, animated GIF, Windows Bitmap BMP and SGI.
Using OneApp CineSlider you can create projections that can be distributed
as standalone applications. These are so easy to use that anyone can launch
them just by double-clicking.
System Requirements: Mac OS 7.1 or later, QuickTime 3.0 or later.
OneApp Software Home Page: http://www.kagi.com/oneapp/
=3D=3D
OneApp CineSlider =E8 un proiettore di filmati, suoni e immagini, veloce e
facile da usare. OneApp CineSlider ti consente di personalizzare la
proiezione per adattarla alle pi=F9 svariate esigenze, =E8 possibile creare
proiezioni automatiche o manuali, personalizzare l'ambiente di proiezione
con sfondi colorati o motivi, utilizzare una colonna sonora durante la
proiezione, visualizzare e fare leggere il nome delle immagini e dei
filmati proiettati.
OneApp CineSlider pu=F2 proiettare ed eseguire un elevato numero di formati
grafici e multimediali: filmati QuickTime, filmati QuickTime VR, file audio
AIFF e tutti i principali formati grafici come JPEG, TIFF, Pict, Photoshop,
PNG, MacPaint, GIF, GIF animate, Windows Bitmap BMP e SGI.
Con OneApp CineSlider =E8 possibile creare delle proiezioni da distribuire
come applicazioni standalone avviabili con doppio clic dal Finder.
Requisiti di sistema: Mac OS 7.1 o successivo, QuickTime 3.0 o successivo.
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
[Archived as /info-mac/gst/oneapp-cineslider-40-it.hqx; 2252K]
Date: Mon, 19 Oct 1998 22:48:51 -0700
Subject: [*] Palms Kaleidoscope scheme
Please post "Palms" Kal. 2.0 scheme on your recent additions page.
-Martha Royer
[Archived as /info-mac/gui/ks/palms-for-kaleidoscope.hqx; 695K]
Date: Mon, 19 Oct 1998 22:48:53 -0700
Subject: [*] Pharaoh Kaleioscope scheme
Pharaoh is based on images from ancient Egpyt and is wriiten for Kal. 2.0.
Please post on your recent additions page.
-Martha Royer
[Archived as /info-mac/gui/ks/pharaoh-kal-scheme.hqx; 618K]
Date: Mon, 19 Oct 1998 22:49:14 -0700
Subject: [*] PictureSnooper98
Subject: PictureSnooper98 V1.0 AutoSearch/Download Binaries Off NewsGroups
Tired of waiting for pictures to download? Searching for that perfect
ClipArt, or Raytraced Images (or other binary file), but can't stand
searching through GigaBytes of Postings? That is why I wrote
PictureSnooper!!
PictureSnooper is an Application that Searches UseNet NewsGroups for binary
files, while you are having dinner, at the movies, or even sleeping. These
binary files are usually pictures (and sometimes executables and HTML
files). After finding a binary file, PictureSnooper downloads the file,
decodes that file, and saves that file to the directory of your choice for
later viewing.
New Features in PictureSnooper98:
* New Window that allows user to display the last image downloaded (for
previewing)
* Added the ability to filter postings by Author
* Option to Add Subject/Author Information to the Finder's Get Info Box for
the file
* Automatic combining of segmented files
* Option to allow for files with the same file name to be stored in the
download directory
* Fixed some handling of certain server errors.
* Modified the file saving to handle PC directories in file names
Requires:
* System 7.0 or Later.
* QuickTime 2.5 or Higher
* Macintosh with the Thread Manager Extension (Later System
Versions Have ThreadManager Built In).
* Access To A News Server Through Your Internet Provider.
Michael
QSys Software
[Archived as /info-mac/comm/inet/picture-snooper-98.hqx; 1225K]
Date: Mon, 19 Oct 1998 22:49:00 -0700
Subject: [*] Power Windows 2.0.4
Power Windows 2.0.4 -- October 4, 1998
by Greg Landweber, coauthor of Kaleidoscope
The Power Windows control panel lets you drag entire windows instead
of dotted outlines. It offers both solid and translucent window dragging
and is the only such utility to support the Finder's popup windows (aka
tabbed windows) introduced in Mac OS 8.
Version 2.0.4 is now compatible with Mac OS 8.5. It also offers various
minor fixes and improvements, including fixes for two bugs introduced
in the short-lived version 2.0.3.
The shareware fee is $10 (registered users of 1.x can upgrade for $5;
registered users of version 2.x do not need to pay an upgrade fee).
-- Greg Landweber
[Archived as /info-mac/gui/power-windows-204.hqx; 100K]
Date: Mon, 19 Oct 1998 22:49:15 -0700
Subject: [*] ShockBox Version 1.0.2
What is it?
ShockBox is an Internet and desktop "audio" browser that allows you to listen to
Shockwave "streaming" audio located on the Internet and on your hard drive.
ShockBox's Internet abilities allow you to connect to different ShockBox Servers
then build custom playlists. You can then shuffle your playlists and play them
back. "Streaming" sound begins playing while it is still downloading. ShockBox's
streaming capabilities provide almost instant playback of high-quality audio,
even for users with 28.8 modem connections to the Internet. ShockBox requires
less computer memory to function than the average Web browser with audio
plug-ins
and ShockBox will run satisfactorily when connected to the Internet with a 56
modem connection. New in Version 1.0.2! Your entire music library is instantly
available on your computer! With ShockBox, high fidelity music can be played
wherever the user takes his/her laptop. Large stacks of physical CDs stay
conveniently and safely at home. ShockBox now allows you play music CDs in
highly
compressed CD-quality Shockwave audio on your hard drive or local hard drive.
Compress your audio, label your audio files with the suffix ".swa" and drop them
in a folder labeled with the CD title and you're ready to create customized
playlists for playback. Plus, drop a JPEG image of the CD cover into the same
folder and view the CD image while you listen to the CD audio tracks! System
Requirements: PowerPC Macintosh (100mhz minimum recommended) with 4MB
memory. You
must have Internet access to use ShockBox Internet abilities. It is recommend
that you have a 56 modem connection or higher when using the Internet abilities
of ShockBox.
[Archived as /info-mac/comm/inet/shockbox-102.hqx; 2966K]
Date: Mon, 19 Oct 1998 22:49:08 -0700
Subject: [*] Smile 1.5.2, a free AppleScript editor
Smile is a free, PPC-only, text and script editor for AppleScript. It
supports applets and droplets.
With respect to other editors, Smile works in a new fashion. The text
windows behave like a shell for AppleScript. Pressing the Enter key
executes (or just compiles, if there is nothing to execute) the current
line or the selected text; the result is appended to the text, or
redirected to the "Result" window. Variables and handlers you have
compiled in a text window remain available until you quit. Smile can be
used as a debugger. You write and test scripts line by line. You drag
chunks from a script, including the properties and handlers it needs, and
test them in a text window.
Moreover, Smile comes with AppleScript additions: list and string
utilities, coercions, script handling, resource reading and writing, math
functions, data publishing etc.
Most of these additions are also included in a Scripting Addition, the
Satimage osax, which is part of the Smile package. You can use the
Satimage osax independently of Smile.
Smile has a User Scripts menu. Each item launches the corresponding
script stored in the "User scripts" folder.
To edit and save scripts, you use the script windows. Like the text
windows they support "Find" and "Compare".
Smile is also a scriptable text editor, supporting color and styled text.
Power users can build quickly a full interface with Smile. Text and
script windows can be equipped with scriptable buttons. Smile has
scriptable dialogs. You first freely design a dialog with some resource
editor. Then, in Smile, you attach to it the script which will handle its
behavior. Lastly you write, where suitable, the script which will launch
the dialog.
[Archived as /info-mac/dev/osa/smile-152.hqx; 863K]
Date: Mon, 19 Oct 1998 22:49:01 -0700
Subject: [*] tetratrap-10.hqx
TetraTrap is an accessory using QuickDraw3D and QuickTime's special effect.
In this 3D world, there are a plate, a sphere, and a gasket. The plate and the
sphere are texture-mapped objects. The sphere spins and is trapped by the
rotating gasket. The gasket changes its color as the time goes by. TetraTrap
can load a still image file as the texture map. Various import formats that
QuickTime supports are allowed. Special effects: fire, cloud, and water
ripple, are shown in front of the view. Flying-thru is done by keyboard input.
[Archived as /info-mac/gst/tetra-trap-10.hqx; 682K]
Date: Mon, 19 Oct 1998 21:00:00 -0700
Subject: [*] TidBITS#451/19-Oct-98
Steve Jobs capped last week by announcing $106 million in quarterly
earnings, a profitable year, and the long-awaited Mac OS 8.5. The positive
financials are great, but everyone wants to know about Mac OS 8.5, so
Technical Editor Geoff Duncan delves into the important new features and
major conflicts. Also, Adam presents his ideas for reviving old software,
and we report on the release of Keep It Up 2.0.1 and the numerous problem
reports about Norton Utilities 4.0.
Topics:
MailBITS/19-Oct-98
Electronic Phoenix Project
Getting Started with Mac OS 8.5
[Archived as /info-mac/per/tb/tidbits-451.etx; 30K]
Date: Mon, 19 Oct 1998 22:49:07 -0700
Subject: [*] Un-SourceSafe Abstract
Un-SourceSafe 1.0
User's Guide
=A91998 Michael Amorose
All Rights Reserved Worldwide.
What is it?
Un-SourceSafe is a Macintosh application which removes the info that
Microsoft's Visual SourceSafe adds to any files you add to a SourceSafe
database. On the Macintosh, Metrowerk's Visual SourceSafe Client usually
adds a 'ckid' resource and sets the file's Finder label color to green or
red. Un-SourceSafe strips this information.
How do I use it?
How many times have you wanted to open a file which has been added to a
SourceSafe database, but not checked out, only to be told that "This file
is read-only"? Pretty frustrating, isn't it? Well, just drop a file, group
of files, or combination of files and folders onto Un-SourceSafe and it
will remove all that nasty info any make any files dropped onto it "normal"
again. But beware that if you do this, SourceSafe can no longer determine
the file's checkout or revision status!
There are two versions of the app: one is named "Un-SourceSafe G3" - this
version should only be run on G3-based Macs. The other version is simply
named "Un-SourceSafe". This version is for all other non-G3-based PowerPC
Macs.
Limitations
Un-SourceSafe can only modify files nested 100 levels deep. If you have a
folder with more than 100 sub folders, you will have to split the drop up
into fewer levels, drop the individual folders onto Un-SourceSafe and then
move the folders back. In addition, the maximum number of items that can be
changed in any given folder in one drop is 1000. Due to memory
limitations, you cannot drop disks onto Un-SourceSafe.
How much is it?
Un-SourceSafe is free and you can freely distribute it as long as this
document accompanies it and you do not sell it or include it in any product
that you charge for.
Un-SourceSafe is a PowerPC-only and so runs only on PowerPC-based Macs.
Please send any problems, bugs, or suggestions to:
Michael C. Amorose
P.O. Box 610217
San Jose, CA 95161-0217
USA
Email: [email protected]
http://www.home.earthlink.net/~amorose
[Archived as /info-mac/dev/uss.hqx; 1126K]
Date: Mon, 19 Oct 1998 22:48:36 -0700
Subject: [*] YellowView 2.1.1
Need you a fast way to build stand-alone multi page documentation? or a
Reference system? or a Help System? Should have, the program you need, a
very low cost? Should be, the applications created, under free distribution?
YellowView is what you want!
You may build a YellowView's stand-alone documentation by dragging text
files onto its icon or onto its window or by means of menus. You may create
68k, PPC or FAT binary YellowView's applications.
YellowView's stand-alone documentations are WASTE based applications having
some special features:
Any individual page has no 32K text size limit. Full WorldScript support.
Double-byte/bidirectional scripts support. Multi-styled text. Drag Manager
support. Translucent Drag-and-Drop. Embedded objects (images, sounds,
QuickDraw3D, QuickTime). Real tabs. Fully justified text.
Command-clicking of URLs (by using Internet Config). Text selection.
Bookmarks for any individual page. Live scrolling. SmartScroll support.
Searching and opening of text selection (simple hypertext feature). Search
features (also across the whole application). SpeechManager support.
Last, but not least, YellowView's stand-alone documentations support five
kind of AppleEvents, with related AppleScript commands, for searching
words or pages. This feature allows to configure YellowView's applications
as Help or Reference System.
YellowView is $10 SHAREWARE. After a trial period of one week it allows to
build applications containing only one document. If you register it you may
againg build multi-page applications. All YellowView's stand-alone
documentations can be freely distributed.
YellowView is Appearance Savvy, Internet Config aware and requires at least
System 7 to run.
Author: Rocco Moliterno
http://yellowsoft.home.ml.org/
http://yellowsoft.home.ml.org/yellowview.html
[Archived as /info-mac/text/yellow-view-211.hqx; 322K]
Date: Mon, 19 Oct 1998 22:48:42 -0700
Subject: [*] YP Refraction (french version)
YP Refraction 1.0F
This is the french version of YP Refraction.
Simule la refraction lumineuse dans differentes formes de prismes.
Mise a Jour: Septembre 1998
Auteur: Yves Pelletier
Email: [email protected] ou [email protected]
WWW: http://www.ncf.carleton.ca/~ch865/
Prix: $15 US
Description du logiciel:
YP Refraction est un didacticiel concu pour l'apprentissage des
lois de la refraction en optique geometrique. L'utilisateur
dispose d'une source laser pouvant etre d=E9placee autour d'un prisme. Six
prismes differents sont disponibles: simple interface lineaire entre deux
milieux d'indices de refraction differents, prisme en forme de demi-cercle,
prisme carre, prisme rectangulaire, prisme triangulaire equilateral
(60=B0-60=B0-60=B0), et prisme triangulaire isocele (90=B0-45=B0-45=B0). L'=
utilisateur
peut modifier les indices de refraction. Il est possible d'afficher la
normale a chaque point d'incidence, ainsi que l'angle entre le rayon laser
et chaque normale. Le schema obtenu peut etre copie, imprime ou sauvegarde
sous la forme d'un fichier PICT.
Yves Pelletier
http://www.kagi.com/pelletier
[Archived as /info-mac/sci/yp-refraction-10-fr.hqx; 256K]
--Info-Mac-Digest--
