Van Basco MIDI/Karaoke software For Mac
Recent convert to Mac and very pleased. Major problem is my inability to get Windows based Van Basco software to work on my Mac.
Any ideas will be appreciated.
Thanks
Thanks
Re: Van Basco MIDI/Karaoke software For Mac
Qmidi might be your solution. Let us know if that works for you?
Finally able to get MIDI files from Van Basco Search to play on Mac and to successfully transfer to external floppy disk. downloaded Qmidi but have not been able to figure out how to use it. Also, wound up with something entitled Karaoke5 but haven't figured it out yet either.
I've been using this program and it's just wonderful - stable, simple and effective. One thought I want to add. If only the developers of this could expand it into a mid-kar CREATION program. This is sadly lacking in the Mac world as far as I know....thus I do my creation work on PC and move it to Mac - it works but it's a pain.
I need download the software Van Basco for mac
As has been mentioned above, there is no Mac version of Van Basco software.Helgard wrote:I need download the software Van Basco for mac
You can try MidiCo Karaoke for Mac. It's more advanced than vanbasco and it's Mac native.
I don't know if I can post the link, so... google ""midico mac karaoke""
