DrBeamProDemo
DrBeamProDemo
Post by Info-Mac » March 23rd, 1999, 11:00 am
Download: http://archive.info-mac.org/sci/dr-beam-pro-demo.hqx
Dr. Beam Pro is a direct manipulation, real-time feedback, beam analysis
program. It excels at rapid prototyping and solution generation for elastic
beams. As the name states, Dr. Beam is a beam specialist, and in the Dr.'s
studio, analyzing a beam is easier than drawing it. Use it once and you
will no longer tolerate the primitive nature of other beam analysis tools.
Dr. Beam Pro features include:
* Direct manipulation / real-time visual feedback
* Deflection, rotation, moment and shear diagrams
* Fixed and pinned supports, internal hinges, plastic hinges, linear
and rotational springs
* Ramp loads, distributed loads, point loads, applied moments and
support settlements
* Editable values of E, I, A and Length
* Unlimited number of loads and supports
* Envelopes to accumulate deflection and moment data.
* Customizable units and feedback formatting
* Ten leveles of undo and redo
* Axial loadings
* much, much more
Stephen Cooper
Manager, Dr. Software, LLC
Seattle, WA
