Easy Installer 1.0
Easy Installer 1.0
Post by Info-Mac » June 28th, 1996, 9:00 am
Download: http://archive.info-mac.org/cmp/easy-installer-10.hqx
This upload is to save you the time of creating the installer
yourself and also to give you the idea. This self-installing
archive installs control panels, extensions, preferences, etc. into
the system folder, and can install stuff into root as well. It's not
as refined or as idiot-proof as a Stuffit Installer Maker installer
but it does work, is easier to create, and I believe Compact Pro is
also cheaper.
What it's good for:
*Creating a product installer
*ORGANIZING YOUR COLLECTION OF INITS AND CDEVS.
The sysem folder is not a good place to keep anything you plan on
keeping beyond the next system melt down. Put your inits/cdevs into
this installer once and for all. Double click and they're installed.
If you do use Compact Pro, please pay the [inexpensive] Compact Pro
shareware fee. Note: I have nothing to do with Compact Pro - I'm
just a satisfied user.
May be included on the CD-ROM. It's freeware, but it
requires the Compact Pro shareware program.
